Old 09-30-2013, 06:45 PM   #1
Smile Sunseeker 2013 3010 ds
Does anyone have a wiring diagram ,fuse location for this motorhome,any help will be appreciated
migcamper is offline   Reply With Quote
Old 11-20-2013, 09:55 AM   #2
Own a 2012 Sunseeker DS. "Assuming" that the location is the same, there's two panels: one on the left side of the entry step (with diagram inside) and one at the base of the bed. There is a breaker located on the generator and a fuse for the water heater in the panel with the water filter. Hope this helps.
rcstroll is offline   Reply With Quote
Old 11-29-2013, 11:25 AM   #3
Question on the 3010ds. I am looking at this model at the local dealer and would like to know how easy is it to get along side the bed at the back side of the coach? My wife uses a Cain and sleeps on that side of the bed, she can't change, cause after her stroke she sleeps on her left side. Thanks
rekwiat is offline   Reply With Quote
Old 11-29-2013, 07:37 PM   #4
[QUOTE="rekwiat;505393"]Question on the 3010ds. I am looking at this model at the local dealer and would like to know how easy is it to get along side the bed at the back side of the coach? My wife uses a Cain and sleeps on that side of the bed, she can't change, cause after her stroke she sleeps on her left side. Thanks[/QUOTE
I own a 2013 3010ds for one year. It is a tight space along the back of the coach window and the bed. I sleep on that side. My recommendation is to have your wife try to navigate the space before you buy. Also have her try to get into bed with the slide not out in case you stop somewhere overnight where the slide is not extended.
kswing60 is offline   Reply With Quote
Old 12-01-2013, 03:29 PM   #5
Your dealer (or contact "April" of customer service at Forest River) should be able to get wiring diagrams for you. That's how I got mine for a 3120.
ATVer is offline   Reply With Quote
2013, sunseeker
