Originally Posted by Sandymplz
First time towing Honda CR-V with 2013 new-to-us Sunseeker 2250. Latest Blue Ox system. Fighting steering wheel constantly to stay on the road. Weight is good; is Honda wheelbase too long for this unit? Any solutions? Help- we've got 2800 miles to go!!
I have no experience towing so if the towing is causing your problem I can't help.
How does it steer when not towing?
I could fall asleep and my 2250 Chevy would go straight down the road. Slight exaggeration. Very little steering correction needed.
So if problem occurs when not towing you should check your tire pressures first. Tires on the same axel should have the same pressure. If pressure is OK then you need to have alignment and steering mechanicals checked.
Long ago I was a service writer and saw complaints of steering problems that were caused by incorrect tire pressure in cars and light trucks I imagine even a small motorhome will be affected by same.
