Old 05-01-2016, 12:43 AM   #1
Delco Bobby's Avatar
Sunseeker 2250 tire pressure
I know that I should have weighed my rig but there is no place convenient to do so. I have my tire pressures set to what the door sticker says. 65 front and 80 rear. Seems fine to me.
I believe that I am no where near the maximum weight that this vehicle can handle.
I am curious as to what other 2250 owners set their pressure to, especially on the Chevy chassis.
Only Sunseeker 2250 owners should answer this post.
Just kidding, all replies are welcome. (That was an unnecessary joke)
Bobby
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 05-01-2016, 08:17 AM   #2
geeman53's Avatar
DB -We're running the stock pressure . I have to pull the rear liners to check- no fun , but worth the trouble.
2016 sunseeker 2250slec
1988 Jayco p.u.,Coleman Plantation p.u.,1989 Jayco class c, Coachman TT,1995 Little Eddie fthwheel,2007 Heartland Sundance 2500 lS fthwheel
geeman53 is offline   Reply With Quote
Old 05-01-2016, 01:14 PM   #3
Thanks.
2018 Ford F-150
Old 05-01-2016, 10:54 PM   #4
Total Loss's Avatar
I am running 65-70 (no heavy added load) in rear.
70 in front.
Read up on the Generals with their recommended pressures based on weight.
These rigs are under-loaded by a lot based on max.
80 psi is for max (14k) and probably ride like Flintstone wheels.
You are probably around 11k loaded- unless you have a lot of tongue weight.
I was at 10200 with half tanks (fuel and water) and typical stuff. Not loaded for a trip.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 05-01-2016, 11:12 PM   #5
70 in front.
I gotta get off my butt and get weighed. There are three CAT scales in NJ that are not a long trip.
I wonder if there is a time of day when they are the least busy. Or day of the week.
2018 Ford F-150
Old 05-03-2016, 02:10 PM   #6
The max weight rating on the 4500 is 14K lbs; our running weight is 10850lbs. We still have a touch over 3000 lbs capacity, but it would depend on each Gross Axle Weight, of which I don't have the numbers handy at the moment.
Generally, tire pressure is subjective, to a point. A minimum pressure is required depending on the weight the tire is carrying. For example, our unit weighed in at the following 2 weeks ago at the conclusion of our maiden voyage:
3950 Front
1950 LF
2000 RF
6850 Rear
3400 LR /2=1700
3300 RR /2=1650
Therefore, looking at the pressure tables at Michelin (which applies to all brands - this is a federal standard rather than a Michelin standard) for LT225/75R16 E: Michelin RV Tires | View Michelin RV Tires load and inflation tables for motorhomes and recreational vehicles. | Michelin RV Tires
Pressure Load position
51 1950 LF
52 2000 RF
42 3400 LR /2=1700
42 3300 RR /2=1650
Note these are the minimum pressures for those loads. I tend to run more pressure to firm up the tires for handling and ride, but not so full that they become harsh. We are still experimenting, but we ran 65Lbs in each tire the first trip. I felt the rears were fine, but the front seemed a little soft.
Help that hopes!
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 05-03-2016, 02:33 PM   #7
3950 Front
1950 LF
2000 RF
6850 Rear
3400 LR /2=1700
3300 RR /2=1650
51 1950 LF
52 2000 RF
42 3400 LR /2=1700
42 3300 RR /2=1650
Help that hopes!
Wow, brucemc, that is a huge help.
My pressure is much higher than those numbers and I was concerned because I dropped lower than the 65 front and 80 rear on the door jamb.
However, I have read in several places that the tire air pressure should be set the same for all tires on the same axle.
2018 Ford F-150
Old 05-03-2016, 02:42 PM   #8
I tend to run the same on each axle, and always have. That's a good rule-of-thumb; the numbers I listed were purely based on the loads. Therefore, as a minimum, use the highest number of the two for all tires on the same axle.
RV On!
2016 2250LE/Chevy
Old 05-03-2016, 04:07 PM   #9
Total Loss's Avatar
3950 Front
1950 LF
2000 RF
6850 Rear
3400 LR /2=1700
3300 RR /2=1650
51 1950 LF
52 2000 RF
42 3400 LR /2=1700
42 3300 RR /2=1650
Help that hopes!
Thanks for the hub weights.
My scale only did a complete.
I guessed (educated) on the axle/hub weight per corner.
I was very close.
I am running 65 rears and 70 front for this weekend's trip.
600 miles round trip.
No hitch load- just toad.
W. Churchill
Old 05-04-2016, 05:24 PM   #10
Door Jamb labels, for reference:
--Bruce.
2016 2250LE/Chevy
pressure, sunseeker, tire
