Old 09-23-2012, 10:26 PM   #1
Sunseeker 2300 rear tv wall mount?
I want to put a tv on the spot on the bedroom wall where the outlet for the cable and 12 volt/110 volt receptacle is. What is the proper area to attach a wall mount to, as there seems to be no studs except on the edges? TIA Floyd
vacouple is offline   Reply With Quote
Old 09-24-2012, 09:57 AM   #2
MotocrossCamper's Avatar
What year is your Sunseeker? I thought I remember somebody saying there is suppose to be backing in the new ones.
MotocrossCamper is offline   Reply With Quote
Old 09-28-2012, 01:04 AM   #3
It is a 2012 2300 sunseeker.
Old 09-28-2012, 10:07 AM   #4
Coachmen Adrenaline
There is a 1/2" thick plywood backer located 42 1/2" up from bottom of cabinet. The backer is then 12" tall and spans 22 3/8" wide. I will try to upload a photo from inside of cabinet to show what it looks like(or similar to).
jamiller45 is offline   Reply With Quote
Old 09-28-2012, 10:09 AM   #5
Coachmen Adrenaline
I am on this forum to help as I can, and am in no way the official response of Forest River, Inc.
Old 09-28-2012, 10:10 AM   #6
Thank you! I thought it was there I just didn't know measurements.
Old 10-01-2012, 07:42 PM   #7
Ok just so I am clear on this, this backer is actually back to side (right side) to the refrigerator and right next to the pleated room divider? if that is accurate then it is right above the furnished outlets for the ac/dc/ 120v. and cable plug...correct?? Floyd
Old 10-02-2012, 07:48 AM   #8
Coachmen Adrenaline
Send me a pm with email address and I will send a higlighted PDF of the refer cabinet showing where this is.
Old 10-02-2012, 03:55 PM   #9
Backer panel on my 2011 Sunseeker 2650
I have my outlets, cable plug, DC power outey and Thermostat in the bed room on the back wall of the Shower stall, is this backer plate the same dimension off of the floor? When facing the wall, the pleated bi-fold is to the right.
Joerossi is offline   Reply With Quote
Old 10-04-2012, 10:47 AM   #10
Coachmen Adrenaline
It is probably in a diff location on the 2650. Give me a little bit and I will look over the prints for you. If you want to pm me an email address, I will send a pdf of the print to you as I did for vacouple
