Old 10-08-2019, 07:05 PM   #1
Sunseeker 2500TS
Sunseeker 2500TS Antenna booster
Well the dealer couldn't find it and I can't either! Where is the antenna booster. I assume that I need to shut off the AB to get a cable signal (I needed to on other RV's) but I can't locate the little green light. Any ideas?
Sunseeker 2500TS
rocrider50 is offline   Reply With Quote
Old 10-09-2019, 12:15 PM   #2
RedLdr1's Avatar
On our 2500 the antenna booster was located on the passenger side first cabinet wall. See attached photo.
Name:	Antenna Booster location.jpg
Wayne and Christine
2020 Sunseeker MBS 2400Q Due Off Line on 10/17/2019
RedLdr1 is offline   Reply With Quote
Old 10-09-2019, 04:35 PM   #3
Sunseeker 2500TS
Thanks, I'll look there. Inside or outside cabinet
Sunseeker 2500TS
Old 10-09-2019, 04:39 PM   #4
RedLdr1's Avatar
Outside. We had the Trekker cap option so it may have been different than the bunk model. You should be able to follow the coax back to it if it isn't located where ours was.
Looking closely at that picture it looks like the booster may be inside, in the shelf area, on the bunk version.
Wayne and Christine
Old 10-10-2019, 07:23 AM   #5
dcheatwood's Avatar
Using same pic, that's where mine is on the Forester 3011ds. Click image for larger version
2018 Forester 3011 DS
Old 10-10-2019, 12:46 PM   #6
JoePa77's Avatar
On my Forester Bunk model, which are very similar to the Sunseeker it is inside the cabinet. You just canít see the light because the coax blocks it from view.
JoePa77 is online now   Reply With Quote
Old 10-10-2019, 04:42 PM   #7
Sunseeker 2500TS
Sunseeker 2500TS
Old 10-10-2019, 04:46 PM   #8
I have a 2018 sunseeker 25 we mbs The button for the booster is located in the small shelf with a door next to the Jensen system. There is 12 volt plug with a red light on it as well as a coax cable. The booster is located on a small button behind all this. Very hard to see.
Rob Burney is offline   Reply With Quote
Old 10-11-2019, 11:51 AM   #9
Garrette's Avatar
2014 3170DS. Do not know if FR uses these now or not but it is a booster. No lights. When you push the button for anything other than antenna, the booster is turned off.
Magnadyne VCS-10
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 10-11-2019, 10:23 PM   #10
It's inside on my 2500 TS
Goatdog is offline   Reply With Quote
Old 10-12-2019, 06:41 PM   #11
Sunseeker 2500TS
Thanks to all, I found it, but would never have if I didn't have help.
Sunseeker 2500TS
500, antenna, sunseeker
