Originally Posted by csmosher
Forgot to give you this info 2015 model
Does the interior light come on inside the fridge? No light - then the button on top is probably not "on". The interior light is the first indicator if your refrigerator is "refrigeration" mode (gas or electric). No light means either the button isn't on or there is a power problem (12 volt or 120 volt).
On the lp gas mode, it does take a couple tries to get the air in the lines burped out. I think the Dometic unit gives 3 tries to light then it will go to error mode (flashing indicator near the power button). To reset the error you have to power off the fridge and then power back on.
After all this - if the fridge is not working on 120 volt, check the back of the refrigerator and make certain it is plugged in.
It does take time for these refrigerators to cool down - the back wall of the freezer is the first to chill.
Bobby
