Old 12-09-2015, 02:32 PM   #1
Sunseeker 2800QS Electric Brakes
I have a 2015 Sunseeker 2800QS which is on a 2014 E450 chassis and I'm going to pull a tow dolly with electric brakes ,does anybody out there know if I was to buy the electric brake controller with the Ford E450 harness is the motor home just a plug and play or do I need to splice into the wires. Thanks
Stormin Norman is offline   Reply With Quote
Old 12-11-2015, 06:36 PM   #2
You can check to see If your vehicle is wired for brakes if you remove the cover under the steering column you should see a female electrical connector about an inch wide.
2016 Sunseeker 2700DS
2010 Jeep Liberty Toad
tlf65 is offline   Reply With Quote
Old 12-11-2015, 07:04 PM   #3
Thanks all set
280, brakes, electric, sunseeker
