Old 03-09-2013, 08:49 PM   #1
Sunseeker 3010DS
I have a 2013 Sunseeker 32. The vehicle has air suspension. What is the required air pressure for the air suspension. Thanks
Kiami2001 is offline   Reply With Quote
Old 03-10-2013, 05:22 AM   #2
Max pressure is 100 psi. Anything under that is acceptable. An empty vehicle would need only 10 psi. Add air for heavy loads, towing trailer, car, etc. Increasing pressure can be helpful if driving in a strong crosswind to minimize sideways push when trucks pass, etc. Also look at how the coach sits when loaded. Rear end should be level or just slightly higher than front. Adjust air to achieve desired angle. Check side to side level and adjust as needed.
Mostly it is personal preference. Try different pressures. I'm currently running about 45 psi.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
