Old 03-13-2014, 01:32 PM   #1
Sunseeker 3010DS Blackwater Tank Flushing System
My blackwater tank flushing system seems to be a casualty of recent cold weather in Texas because instead of flushing the tank it flooded my bathroom. From where do I access it for repairs? Is it behind the bedroom dresser drawers? Any suggestion will be appreciated.
lshields01 is offline   Reply With Quote
Old 03-13-2014, 01:47 PM   #2
Can someone tell me how to access the blackwater tank flushing system in a Sunseeker 3010DS? Is it behind the bedroom dresser drawers?
Old 03-14-2014, 01:24 PM   #3
Does it have the fresh water flush? A hose connection to flush tank?
DrJMB is offline   Reply With Quote
Old 03-14-2014, 10:16 PM   #4
DrJMB, yes, it is the hose connection for a freshwater flush.
Old 03-14-2014, 10:26 PM   #5
VinceU's Avatar
You're looking for a "vacuum breaker" mounted about 5-6 feet above the floor maybe in a closet or void. There will be two pex piping runs to it each of 1/2" size. The piping is from the hose connection to the bottom of the valve and the outlet leads to the side of the tank. I prevents flow from the tank to the fresh water system by not allowing the water to flow "backwards". If the seating disc gets stuck the supply water will flood the space its in. You know the approx. location already, where all the water came from. Easy to change or repair.
Old 03-15-2014, 05:56 AM   #6
fonzie's Avatar
X2
Here is what you are looking for.
Fonzie
Old 03-16-2014, 06:09 PM   #7
did you mopen the black water dump valve before your flushed the tank. I was told if you don't it will come back up thru the toilet
walterhess is offline   Reply With Quote
Old 03-20-2014, 05:07 PM   #8
So does the black tank flusher have to be winterized??? I never gave it a thought.
But to your question, as someone else asked, did you have your dump valve open? Is it blocked up?
Snowman9000 is offline   Reply With Quote
Old 03-20-2014, 05:09 PM   #9
fonzie's Avatar
Yes it should, at least low compressed air through it, some push anti-freeze. It supposed to self drain but I don't take a chance.
Fonzie
Old 03-20-2014, 05:16 PM   #10
The flush is designed to be gravity flow after flush.
black, sunseeker, tank, water, water tank
