Old 05-11-2015, 09:59 PM   #1
Sunseeker 3010DS - Jensen 32" question
The 12V power cable for my tv doesn't work anymore. The little metal "nipple" is stuck inside. I've tried everything but I think the next step is to buy a new one. I'm traveling right now so I can't order the Jensen one in time. I want to run to a Best Buy type store and buy a universal 12V charger with different tips. My question... do you know how many amps this thing needs? I saw one the other day that had different settings... 1.5a, 2a, 3a, etc. All the way up to 6amps. Does anyone know? It's for the Jensen JE3212LED model
jjlavin is offline   Reply With Quote
Old 05-12-2015, 08:17 AM   #2
The manual says 7.5 amp. Click image for larger version
Name:	ImageUploadedByForest River Forums1431436623.225287.jpg
steverkemp is online now   Reply With Quote
Old 05-12-2015, 08:20 AM   #3
I would think a big truck stop that stocks a lot of 12v products might have a 7.5 amp rated adapter.
Old 05-12-2015, 09:10 AM   #4
Perfect! Thanks much!
Old 05-12-2015, 03:25 PM   #5
The power cable end seems to be a really poor design. Ours was acting up when we picked up our new unit this spring and has already failed. Our dealer has ordered one for us from Forester. It seems really flimsy. I may consider finding a more durable replacement as well. Good luck in your hunt.
Dino61 is offline   Reply With Quote
Old 05-12-2015, 04:14 PM   #6
No kidding Dino. If you breath on it, it goes out
Old 05-12-2015, 07:50 PM   #7
Jensen 12v plug
Mine melted and I found one at Radio Shack.
J. V.
2015 Sunseeker 3050s
15 Years Full Timing
Now own Sticks and Bricks
J. V. is offline   Reply With Quote
Old 05-12-2015, 08:48 PM   #8
Are you serious? Melted?
Old 05-13-2015, 03:26 PM   #9
I have a couple questions on this same TV. How do you remove this tv from where it is mounted? Where are the HDMI inputs? I also have a 3010.
Sun seeking is offline   Reply With Quote
Old 05-13-2015, 05:10 PM   #10
Just grab hold off the sides, push it up towards the ceiling, then slowly start to pull toward you. It will come out of the bracket very easily. The hdmi ports are on the back
jensen, sunseeker
