Old 09-24-2017, 08:36 PM   #1
Sunseeker 3050s owner question
Can owner advise .e where the swintech controller is located. My rear drive will not move the bedroom. Rear is stuck open 5 inches. Re syncing is no help. Earliest appt at service center not till 11/15.
NJwoodworker is offline   Reply With Quote
Old 09-24-2017, 08:50 PM   #2
Did you try the Schwinntek website?
GMax is offline   Reply With Quote
Old 09-24-2017, 09:08 PM   #3
Not much help. Error 404 trying to download service related manuals.
Old 09-24-2017, 10:00 PM   #4
It should be behind the panel below your oven. There are 4 screws holding the panel on in the corners.
2017.5 Forester 3051S
2016 Honda Accord
Steve-W is offline   Reply With Quote
Old 09-25-2017, 12:09 PM   #5
Sunseeker panel
We have recently had some work done and if you mean the slide control board we were told it is located under the sink area behind a wood panel.
Good luck to you.
sunseekercamper56 is offline   Reply With Quote
Old 09-25-2017, 02:11 PM   #6
mkekflyers's Avatar
Where Steve said..panel under the oven/stove....4 screws...
2018 Georgetown 378 XL
2012 Ford Edge TOAD
Blue Ox & RVIBrake
2014 - 37; 2015 - 58; 2016 - 64;
2017 - 93, 2018 - 224, 2019 - kinda living in her...
mkekflyers is offline   Reply With Quote
Old 09-25-2017, 02:30 PM   #7
JimOneil43's Avatar
Should be the same as our 3051S Forester....behind the wood panel under the cooktop. We had the same problem recently...the front of the slide moved in and the back stayed out and got jammed. Had to get a mobile RV tech out to dis-engage the motors so we could shove it back in manually.
Good Luck
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 09-26-2017, 08:50 AM   #8
Thanks to all. Found controller. There were no codes displayed. Disconnected power leads and reconnected them. Red & green flashed and went out. I was finally able to get rear to close within 3/4 inch.
Also tried removing exterior screw but was unable to lift motor.
Yery disappointed, as i lived thru Irma and evacuated Florida miles round trip with this inoperable and partially open. Dan
Old 09-26-2017, 07:12 PM   #9
mkekflyers's Avatar
Glad you got it in and better than it was..most important you and yours are safe and healthy!
2012 Ford Edge TOAD
Blue Ox & RVIBrake
Old 09-26-2017, 10:56 PM   #10
Thanks, i wound up driving from near Tampa to Charleston to evacuate then return to Florida to assess damage and then back to nj. One of the main reasons we picked the 3050s was queen bed and bathroom were usable with the slide closed. I too am happy to get it mostly closed.
305, 3050s, sunseeker
