Old 01-01-2015, 02:48 PM   #1
Sunseeker 3100SS electrical diagram
I have a 2011 Sunseeker 3100SS that the converter is not keeping the batteries charged while plugged in to 110 source. Where do I check for voltage loss problem?
rmneisler is offline   Reply With Quote
Old 01-01-2015, 03:28 PM   #2
2012 Solera
Our Solera will occasionally trip the converter circuit breaker when connecting to shore power. Sneaky because lights work on 12 volts off battery and most 120 volt items work - but the converter isn't getting power so the batteries are not being charged. When I reset the breaker all is well. I now check the one outlet in my MH that shares the converter breaker each time I connect to shore power.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 01-02-2015, 09:49 PM   #3
There is (at least on 2014 models) a circuit breaker reset for the converter inside of the Battery Isolator circuit board just to the left on the stepwell.
ActionJackson is offline   Reply With Quote
Old 01-03-2015, 01:49 PM   #4
There is not a resettable breaker in that area of the 2011.
Old 01-03-2015, 02:18 PM   #5
The 30 amp main breaker in the interior fuse panel may have been tripped. I reset it and the converter appears to be working. Voltage at the battery terminals is 13.8 Thanks both of you for your help.
Old 01-03-2015, 03:01 PM   #6
bikendan's Avatar
By the way, there is no wiring diagram available, except for the chassis, possibly.
Equalizer WDH
3100ss, electric, electrical, sunseeker
