Old 03-11-2015, 05:18 PM   #11
GM
bclemens's Avatar
The only reason there would be a loop there is if it was a Canadian spec sofa that got installed by accident.
The hinged storage door is only on "flat floor" sofa's like the 3050 or 2700. I'd love to see a picture of this loop to satisfy my curiosity.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 03-11-2015, 06:13 PM   #12
Love My Sunseeker
DXSMac's Avatar
Not sure how to put them in the posts. I made an "album."
Here it is:
Forest River Forums - DXSMac's Album: Couch Loop
Now how do I flatten the couch? As you can see in the second picture, I can't get it out of that position.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 03-11-2015, 06:19 PM   #13
[QUOTE=bclemens;803879]The only reason there would be a loop there is if it was a Canadian spec sofa that got installed by accident.
Are you saying we are Loopy
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 03-11-2015, 06:26 PM   #14
Not 100% sure, but the loop is only to give you a hand hold to pull bottom cushion up, then when seat back cushion is flat you just push down on seat bottom to make into bed.
2014 Forester 3051s
2012 Sonic toad
Old 03-11-2015, 06:29 PM   #15
Yours is a little different than mine but from the underside, it looks like it might operate the same.
Photos of mine. All with the front storage panel removed.
Name:	Normal position.jpg
ID:	71174   Click image for larger version
ID:	71175   Click image for larger version
ID:	71176   Click image for larger version
ID:	71177   Click image for larger version
bgilly is offline   Reply With Quote
Old 03-11-2015, 08:01 PM   #16
GM
bclemens's Avatar
Well, that strap certainly wasn't installed by us. Might have been a dealer add on. Something they do to make it easier. Not a bad idea if I didn't see it currently failing.
Once you get it in that position, then you actually push down on the portion closest to you. If that's not working, then something might be misaligned.
Dinette might be the best option at this point.
Old 03-11-2015, 08:14 PM   #17
hockeytownmom's Avatar
Originally Posted by Joshua Cavitt View Post
The "Loopy" thing is for your storage cover and has nothing to do with the couch folding out. If you have too much underneath your couch you won't be able to pull it out and fold it down.
There should be a metal bar underneath the front of the seat cushion; grab that and pull outwards and up.
Woah! You can use the underneath as storage?!??!? That's awesome!
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 03-11-2015, 08:47 PM   #18
Love My Sunseeker
DXSMac's Avatar
Yeah, there is plenty of room! However, last summer I had it STUFFED, so maybe that is causing a "misalignment" of some sort......
Old 03-11-2015, 09:36 PM   #19
Love My Sunseeker
DXSMac's Avatar
SUCCESS! WD-40 to the rescue! Applied some WD-40 to the hinges, and we have flatten! (as opposed to "liftoff")
Old 03-11-2015, 09:40 PM   #20
Garrette's Avatar
The arm rest are removable to give extra length. Just pull straight up. In fact, it is better to remove the arm rest before letting the couch out because the metal hinges may scrap the material and rip or mar the upholstery.
Garrette is offline   Reply With Quote
3170, sunseeker
