Old 07-02-2018, 05:39 PM   #11
RedLdr1's Avatar
Originally Posted by GL1800Rider View Post
The DW hates the heat and gets uncomfortable with anything above 75 degrees so I just purchased a Fridgidaire 12,000 btu portable that I am going to retrofit and use at the Mayberry FROG rally on the 12th. Hopefully that will solve the problem and keep her happy.
If you don't mind I'd like to check out that unit at Mayberry....
I've used portable A/C units before, with mixed results, in data and call centers when the main A/C unit was down. The biggest problem was getting rid of the condensation...especially in a data center...
Wayne and Christine
2019 Sunseeker 2500TSF "Goldilocks"
RedLdr1 is offline   Reply With Quote
Old 07-02-2018, 05:53 PM   #12
Jeff
Jcf0527's Avatar
Sunseeker A/C Problems
I am using my rig as a mobile office at my mother in law’s while my wife cares for family. Nothing but 15 amp service so I am using a 7k btu portable unit to keep the edge off - does ok in the overnights and mornings but thank goodness for the generator during the heat of the day (we all live in Orlando)! Draining the unit into a 5 gal bucket which goes about 10 hours between dumps and vented the unit through the passenger window. MacGyver engineering at it’s finest. I will send pictures.
Jeff & Peggy
2017 Coachmen Leprechaun 319MBS
Avid campers since 1999
Jcf0527 is offline   Reply With Quote
Old 07-02-2018, 06:04 PM   #13
Jeff
Jcf0527's Avatar
Here are some pics of my set up
[ATTACH]178102[ATTACH]178103[ATTACH]178104
ID:	178102   Click image for larger version
ID:	178103   Click image for larger version
Jeff & Peggy
Old 07-02-2018, 06:06 PM   #14
Jeff
Jcf0527's Avatar
Worked out of the rig last week, another week to go at least! Gets me by in a pinch
Jeff & Peggy
Old 07-02-2018, 07:00 PM   #15
RedLdr1's Avatar
That looks like a good, workable, temporary solution. I used bigger portable A/C units as back ups in my data and call centers and the drainage was always a problem. The ones I had looked like "Robbie The Robot" rejects due to their flexible tube "arms" to point the air flow...
Wayne and Christine
Old 07-02-2018, 08:11 PM   #16
Citrus County, Fl.
GL1800Rider's Avatar
I ran mine in the RV for the first time this afternoon. It was 89 inside and the output temperature was about 62. Not too bad for a temperature difference. After running a couple of hours it got down to 81 inside with a 25 degree difference. Unit was pulling about 9 to 11 amps.
The unit is 15" in diameter, has a remote and can be controlled with an app on the cell phone which I have not set up yet. I should be able to roll it over to the steps and drain the water into a pan and dump it.
Since there was nothing else on except the converter, I tried both the coach AC and the portable for a few minutes and the amp draw was running 24-26 with a voltage drop to 111. Not too bad.
Here are a couple of crude pictures.
Name:	Portable AC ducting.jpg
ID:	178115   Click image for larger version
Name:	Portable AC unit.jpg
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 07-05-2018, 12:59 PM   #17
dcheatwood's Avatar
Your 2018 has the Atwood which is supposed to cool better than my Dometic. With 95 degrees outside and full sun our inside temp will rise to 82 degrees. I have the insulated cushions on the vents, reflectix on the rear window, covers for the inside of the door and also the shower skylight as well as "Heat Shields" on the windshield and driver/passenger windows. I also purchased a sun screen for the awning which seems to help. It also helps to run the generator and turn on the AC on the way to the campground so you don't have to cool down the interior and remove as much humidity when you set up at the campground.
Have you considered how to drain the condensation? I've thought maybe in shower drain if you have full hookups. But what about when you have no sewer hook up?
Nevermind. I read the rest of the thread.
2018 Forester 3011 DS
Old 07-05-2018, 04:02 PM   #18
Jeff
Jcf0527's Avatar
Here’s my solution. 178371[/ATTACH]
Jeff & Peggy
Old 07-05-2018, 07:39 PM   #19
We have a 2013 DS, we just got back from 5 days at Delaware Seashore State Park campground, it was above 90 everyday, even though the AC ran most of the time we kept the thermostat at 74-76 degrees and did not have any issues. Is it possible that your unit could be low on Freon?
Chas69 is offline   Reply With Quote
Old 07-08-2018, 11:25 PM   #20
Sunseeker 2400MBW
Originally Posted by Jcf0527 View Post
Open the vent right on the bottom of the ac unit so the air blows straight out of the unit rather than the vents. So that the unit is “dumping” air straight out. Also, the foam “pillows” that push up into the vent as well as smoke or black vent covers help immensely. Trust me - I live and camp in Florida year round!
I’m glad I read this. We had our air conditioner replaced last year after a big fail and now I was worried about the replacement. 90 degrees in Boise at 9:30pm and motor home was 86 degrees with airco full blast for several hours. My husband said “oh don’t open that wonka wonka wonka ...”
He went to do something outside and I jumped up and opened it. Now 30 minutes later it’s a 72 wonderful degrees. A little cool air still comes out the vents.
Full time 2016 Sunseeker 2400WS towing a 2018 Subaru Forester.
Nancyc7 is offline   Reply With Quote
sunseeker
