06-30-2018, 07:22 PM
Sunseeker A/C Problems
We have a 32-foot 2018 Sunseeker with a 15.5 BTU a/c. It is 95 degrees outside. All windows are covered and shades are down. The a/c has been running steadily for 5 hours and it is still 86 degrees inside.
This is our second trip in our RV. After an earlier trip, we had it checked for blockages because you can barely feel any air coming out of the vents, especially in the bedroom. We were told everything is clear and the a/c is working properly.
Is there anything we can do, or are we destined to only travel in cool weather? Is it possible to add a second unit? How would that work?
Thanks in advance.
06-30-2018, 07:56 PM
Thanks in advance.
No, that is not normal. We have a 34 foot camper with Bunkroom and 3 slides, and we have one 15K BTU AC unit. It cools the camper wonderfully even in outside temps in the 90s. Something is wrong. Can you put it on dump and check it? There is always more effort cooling when its going through the Vents.. If you put the unit on Dump so it just comes straight out it should help.
06-30-2018, 11:00 PM
The 15k btu air conditioner in our 2017 32' Forester can't keep the interior cooler than the mid-eighties if we're parked in the summer sun.
I had the windows tinted which has helped but plan to paint the 3 skylights with white paint for plastic due to the amount of radiant heat coming from them even with their shades closed.
The only way we could enjoy our unit last summer was to close off the bedroom during the day and put the air conditioner on dump. Of course it never cycled because the thermostat is in the hot bedroom but constant cold air was great even if noisy. The fridge liked it too. Good luck finding your issue.
Sent from my SM-N910T using Forest River Forums mobile app
Kirk
2017 Forester 3051S
07-01-2018, 08:23 AM
Thanks for the info. What do you mean by dump? We can’t find anything in manual about that.
07-01-2018, 08:32 AM
Jeff
Open the vent right on the bottom of the ac unit so the air blows straight out of the unit rather than the vents. So that the unit is “dumping” air straight out. Also, the foam “pillows” that push up into the vent as well as smoke or black vent covers help immensely. Trust me - I live and camp in Florida year round!
Jeff & Peggy
2019 Coachmen Mirada 35BH
Avid campers since 1999
07-01-2018, 08:47 AM
There is a panel on the downward face of the a/c that slides maybe 1/2 inch. It blocks the downward "dump" vent and forces the air out the vents that are spread throughout the ceiling. The space above the ceiling is hot so the air ducts absorb this heat and reduce the cooling effect. My experience with low airflow and poor cooling suggests a separation in the ducts. Additionally, a dirty blower wheel can have the same effect.
Sent from my SAMSUNG-SM-G891A using Forest River Forums mobile app
07-01-2018, 09:17 AM
All of the above advice is good. One more thing: After purchasing my current TT, which is a 30 footer, I had a hard time cooling it as I thought it should be cooled and I'm in SW Ga. I removed the plate that the A/C filter is in and the "dump" vent, this plate is the air distribution box or ADB. I found the the areas where the cooled air goes in to the duct work in the ceiling were not sealed off to prevent cooled air from entering the so called "attic" of the TT. I used aluminum tape to cover these gaps. I also removed all six (6) ceiling registers to inspect them and found that between the duct work in the ceiling and the actual ceiling panels there were gaps allowing cooled air to enter into the attic area. Sealing off all these areas where cooled air could escape helped a lot. I eventually decided that the one 15K unit just was not big enough for this 30 footer with two slides so I added another 15K unit. I used the vent over the bed and ran a direct wire to the new A/C which I plug into the 20 amp electrical outlet on the power pedestal. This has worked very well for about two years now.
07-01-2018, 10:45 AM
Jeff
What’s the make and model of your rig, Carole?
Jeff & Peggy
07-01-2018, 11:15 AM
Jeff
Sorry too many conversations going at once lol! I meant 2 buddies - sorry about that!
Jeff & Peggy
07-01-2018, 11:29 AM
Citrus County, Fl.
Your 2018 has the Atwood which is supposed to cool better than my Dometic. With 95 degrees outside and full sun our inside temp will rise to 82 degrees. I have the insulated cushions on the vents, reflectix on the rear window, covers for the inside of the door and also the shower skylight as well as "Heat Shields" on the windshield and driver/passenger windows. I also purchased a sun screen for the awning which seems to help. It also helps to run the generator and turn on the AC on the way to the campground so you don't have to cool down the interior and remove as much humidity when you set up at the campground.
The DW hates the heat and gets uncomfortable with anything above 75 degrees so I just purchased a Fridgidaire 12,000 btu portable that I am going to retrofit and use at the Mayberry FROG rally on the 12th. Hopefully that will solve the problem and keep her happy.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
07-02-2018, 05:39 PM
If you don't mind I'd like to check out that unit at Mayberry....
I've used portable A/C units before, with mixed results, in data and call centers when the main A/C unit was down. The biggest problem was getting rid of the condensation...especially in a data center...
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 Off-line 15 April 2024.
07-02-2018, 05:53 PM
Jeff
I am using my rig as a mobile office at my mother in law’s while my wife cares for family. Nothing but 15 amp service so I am using a 7k btu portable unit to keep the edge off - does ok in the overnights and mornings but thank goodness for the generator during the heat of the day (we all live in Orlando)! Draining the unit into a 5 gal bucket which goes about 10 hours between dumps and vented the unit through the passenger window. MacGyver engineering at it’s finest . I will send pictures.
Jeff & Peggy
07-02-2018, 06:04 PM
Jeff
Here are some pics of my set up
[ATTACH]178102[ATTACH]178103[ATTACH]178104
Jeff & Peggy
07-02-2018, 06:06 PM
Jeff
Worked out of the rig last week, another week to go at least! Gets me by in a pinch
Jeff & Peggy
07-02-2018, 07:00 PM
That looks like a good, workable, temporary solution. I used bigger portable A/C units as back ups in my data and call centers and the drainage was always a problem. The ones I had looked like "Robbie The Robot" rejects due to their flexible tube "arms" to point the air flow...
Wayne
07-02-2018, 08:11 PM
Citrus County, Fl.
I ran mine in the RV for the first time this afternoon. It was 89 inside and the output temperature was about 62. Not too bad for a temperature difference. After running a couple of hours it got down to 81 inside with a 25 degree difference. Unit was pulling about 9 to 11 amps.
The unit is 15" in diameter, has a remote and can be controlled with an app on the cell phone which I have not set up yet. I should be able to roll it over to the steps and drain the water into a pan and dump it.
Since there was nothing else on except the converter, I tried both the coach AC and the portable for a few minutes and the amp draw was running 24-26 with a voltage drop to 111. Not too bad.
Here are a couple of crude pictures.
99 Terry 31G
07-05-2018, 12:59 PM
Have you considered how to drain the condensation? I've thought maybe in shower drain if you have full hookups. But what about when you have no sewer hook up?
Nevermind. I read the rest of the thread.
2018 Forester 3011 DS
07-05-2018, 04:02 PM
Jeff
Here’s my solution . 178371[/ATTACH]
Jeff & Peggy
07-05-2018, 07:39 PM
We have a 2013 DS, we just got back from 5 days at Delaware Seashore State Park campground, it was above 90 everyday, even though the AC ran most of the time we kept the thermostat at 74-76 degrees and did not have any issues. Is it possible that your unit could be low on Freon?
07-08-2018, 11:25 PM
Sunseeker 2400MBW
I’m glad I read this. We had our air conditioner replaced last year after a big fail and now I was worried about the replacement. 90 degrees in Boise at 9:30pm and motor home was 86 degrees with airco full blast for several hours. My husband said “oh don’t open that wonka wonka wonka ...”
He went to do something outside and I jumped up and opened it. Now 30 minutes later it’s a 72 wonderful degrees. A little cool air still comes out the vents.
used to be - Full time 2016 Sunseeker 2400WS towing a 2018 Subaru Forester. 2021 we bought a house.....Still have the precious Sunseeker and tow car.
