Old 06-02-2015, 06:07 AM   #11
shower skylight
If you don't mind, can you send me a link to the reflective material you use for the shower? I've been looking for something easier to shape than those windshield screens
jeffreymhardy is offline   Reply With Quote
Old 06-02-2015, 07:14 AM   #12
got the material at CW in a roll, had enough to do all the windows, bath vent and shower. I also use the outside cover over my windshield. Good luck
Jerry. Vietnam vet.
Retired
jgahlhoff is offline   Reply With Quote
Old 06-02-2015, 07:20 AM   #13
Thanks!
Old 06-03-2015, 07:58 PM   #14
Originally Posted by jeffreymhardy View Post
I have a 3010DS 2015. The other issue is that the AC is so loud it's difficult to even have a conversation in the living room area when it's running, much less watch and hear TV. so far this experience has taught me that I definitely want a fifth wheeler for my "retirement" camper...at least the way those are built deadens the noise of the AC inside the main compartment.
Sounds like you may have the "quick cool " slide vent open where the main filter area is and the cold air is not going through the ducted ceiling. It should not be loud....
ActionJackson is offline   Reply With Quote
Old 06-03-2015, 08:18 PM   #15
Do you have full body paint? The dark sides absorb far more heat than the standard white. Those who have white coaches should put a hand on the white surface and then on a dark stripe while in the sun to feel the difference. It will make you have second thoughts about wanting full paint on your next coach, at least if you use it in the South or Southwest.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 06-03-2015, 09:17 PM   #16
I do know about the quick cool slider but it's still really loud even when the air is being pushed thru the ducts. Maybe this is more of a limitation of any RV without an "attic" that masks much of that noise.
Old 06-03-2015, 09:19 PM   #17
I do have full body paint and that was my first thought as well...however my sales person Dismissed that almost immediately. I think you're right though...that may have more to do with it than anything else...
Old 06-04-2015, 05:34 AM   #18
Could someone on this forum who is in a hot area check the air temperature going into the A/C return and the air temperature coming out of their vents so the poster can compare to his temperatures? The temperature drop from the return to the outlet is the real test of performance. If that's good the problem is the heat load.
Sorry but I can't check it myself.
RamblerGuy
2011 Sunseeker 3100
Old 06-04-2015, 07:36 AM   #19
Maybe you have a blockage in the ceiling ducts? Our A/C isn't an issue to talk over when it is running in our 3100. As suggested, you should check the difference of the air going in at the return and then at the duct outlets or slider vent.
Old 06-14-2015, 08:48 AM   #20
2015 Sunseeker 2300
We have a new 2015 Sunseeker 2300 and the AC works BUT you need ear plugs. IT is
extremely loud inside! We have had so many problems with our unit and this is just one more. Not sure how to quieten it down any suggestions
Gingsnap is offline   Reply With Quote
sunseeker
