Old 09-21-2019, 03:26 PM   #1
Sunseeker ceiling light removal
How on earth do you remove ceiling lights to replace? There are no tabs or screws? We have a 2015 Sunseeker. I am trying to post pics, first time doing this.
Also, we did try squeezing and twisting and turning, didn't work!
Name:	ceiling light 1.jpg
ID:	215494   Click image for larger version
Name:	ceiling light 2.jpg
UK Cards Fan is offline   Reply With Quote
Old 09-22-2019, 10:47 PM   #2
Sunseeker ceiling light lens removal
Just did that to mine! Easy once you know how. Take a small, flat prying device of some kind (I used a nail file) and insert it between the plastic lens and the frame around the lens, then pry it out. It won't (shouldn't!) break. Mine didn't. They pop right out. Be cautious not to insert the tool in very far, as you will (I did) contact the electrical circuit board and short the light out.
Since I was replacing the entire light assembly anyway with a better light, no harm done.
Good luck!
Ohinaz1970 is offline   Reply With Quote
Old 09-23-2019, 02:54 PM   #3
Thanks, will give it a shot. Some of the bulbs are out and flickers when first turned on, then gets strong. Whatever, it is annoying.
Old 09-23-2019, 03:10 PM   #4
cboss's Avatar
Do it when it's warm.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 669
cboss is offline   Reply With Quote
Old 09-23-2019, 09:06 PM   #5
Ceiling light issue
Dear UK Cards Fan:
I ordered the lights from Amazon: "Leisure LED" lights. Several styles to choose from. I replaced all the under-counter lights. A 2-pack was only $14, plus shipping.
Safe travels!
Old 09-24-2019, 04:59 PM   #6
Thanks, will look on Amazon, sure less expensive than an RV supply store!
Old 09-29-2019, 08:44 PM   #7
Mine were flickering and some bulbs not working. Redid the wire / connection and problem solved. Didn't have to replace them at all.
jst3 is offline   Reply With Quote
light, sunseeker
