Old 08-20-2016, 06:47 PM   #11
Everything else works. All the dc stuff is working fine. Lights, fans you name it no problems.
Outside light. Kitchen living room cutoff switches for lights works.
Only problem is water pump and the tank levels.
Is there a fuse somewhere for this stuff?
MikeRP is offline   Reply With Quote
Old 08-21-2016, 05:40 AM   #12
Look on the main power panel, which has both the 120 volt breakers and the 12 volt fuses. I think the convenience panel fuse on our Sunseeker is marked "Monitor".
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 08-21-2016, 07:31 AM   #13
Wolverine 1945's Avatar
Originally Posted by ilmor View Post
Guys, dumb question....what is a WIFCO?
That was not a stupid question,,, Thank You for asking !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-21-2016, 06:22 PM   #14
In some occasions this type of monitoring panels are using the «return to ground» technique; i.e. the switch is providing the connection(or completion) of the circuit to the ground.
So, check if you have a solid «gnd» connection to the panel.
A multimeter is the best camper friend !
HerveVR is offline   Reply With Quote
Old 08-22-2016, 05:29 PM   #15
So I got a multi meter and I'm reading 13.14 volts on each battery disconnected from the pedestal.
With the cheap battery tester I got, I only have 1 ball floating but I'm not sure the thing is right.
I'll disconnect the panel tonight.
Old 08-22-2016, 08:03 PM   #16
I had a similar problem it turned out to be my hitch moved and pinched my ambicil cord and the only thing that worked was the slide out.
NorSnrub is offline   Reply With Quote
Old 08-25-2016, 01:56 PM   #17
Hey everyone, I found the issues. Finally, with the multimeter I checked everything and all was good. Batteries are going bad though. So I took he monitor panel off their wall again. This time one of the slide connections broke off.
So I went to ace hardware and picked up those type connections.
Name:   ImageUploadedByForest River Forums1472151243.134089.jpg
You can see the break. Also the water pump was loose in its socket and the power to the level panel was disconnected.
I got it all partly temp and partly permanent repaired. When I get home , I will redo the connections one by one.
Basically it looks like it's just being jostled apart. But I think they could have done a better job on the attachments.
Thanks all!
Old 08-25-2016, 02:13 PM   #18
SeaDog's Avatar
Thanks for getting back to the forum with what you found and fixed
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 08-25-2016, 07:08 PM   #19
3071DS
Garrette's Avatar
Plan to pull my panel this weekend, just to check. Thank you for posting.
Garrette is offline   Reply With Quote
Old 08-25-2016, 07:28 PM   #20
DW's Retirement Plan
DaGrinch's Avatar
x2.
Preventive maintenance is your friend!
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life...
DaGrinch is offline   Reply With Quote
sunseeker
