Old 06-14-2016, 11:36 AM   #61
2015 Sunseeker 2300
so on an elec awning you are supposed to tighten the black knobs? howwould the awning come in if you did that?
Gingsnap is offline   Reply With Quote
Old 06-15-2016, 06:30 AM   #62
Wolverine 1945's Avatar
My question exactly ???
Maybe we are looking @ this wrong ???
We can only hope more will chime in on this !!!
Wolverine 1945 is offline   Reply With Quote
Old 06-15-2016, 07:04 AM   #63
TURBS's Avatar
As long as the awning hasnt been lowered in the extended position its fine to lock the knob.
If its tightened in the retracted position itll extend and retract fine.
In other words as long as arm is extended "all the way out or up" the knob can be tightened and stay tight.
Once you lower awning or tilt it for rain tilt and tighten knob you cannot retract it whithout loosening knob and extending arm.
Clear as mud?
Sent from my SCH-R530U using Tapatalk
Old 06-15-2016, 07:27 AM   #64
Clear as mud?
THANKS,,, I guess I sent you a Thanks,,,
never used the Thanks button before !!!
Old 06-15-2016, 08:22 AM   #65
TURBS's Avatar
You did and I got it!
Old 06-15-2016, 08:58 AM   #66
Way of subject Ron,,, but I think you would be the man to know,,,
Do most FROGers hang a FROG flag or some thing when camping ???
I have often wonder if there are FROG members in the same CG as we are !!!
Old 06-15-2016, 09:15 AM   #67
Total Loss's Avatar
Clear as mud?
You are as sharp as a spoon
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 06-15-2016, 10:40 AM   #68
TURBS's Avatar
We have two frog flags we fly
Old 06-16-2016, 06:53 PM   #69
MH Noob
Where would one obtain a Frog flag?
Slimjc is offline   Reply With Quote
Old 06-16-2016, 07:12 PM   #70
TURBS's Avatar
At a rally or at the frog store.
Old 06-16-2016, 10:10 PM   #71
Delco Bobby's Avatar
Noise update
I removed almost everything from the RV that I had put in over time. I filled the FW tank. Then took a ride. I was able to identify a couple more noise makers and took care of them. One was a step stool that I thought was held tight by some foam but over time the foam compressed where it was tou hing the stool.
Today I put most of the stuff back in the RV storage compartments and refrigerator, etc. but in a different arrangement. I think I got lucky.
Took an 85 mile trip over familiar roads and it was a pleasure again. Very little noise and quite smooth most of the time. It must have sensed that we were looking at other RVs.
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
door, noise, sunseeker
