View Poll Results: Sunseeker Warranty Issues the First Year?
We have had no warranty issues the first year. 10 15.87%
We had a few minor issues that didn't require sending the MH to the dealer. 9 14.29%
We had issues and returned the unit for warranty work. 40 63.49%
We continue to have issues beyond the first year. 4 6.35%
Voters: 63. You may not vote on this poll
Old 01-11-2014, 07:09 PM   #61
Originally Posted by RvBill3 View Post
I added a swivel base to the passenger seat on our 2012 2300 Chevy. As others said, it gives more seating options besides U dinette. (Driver seat would swivel into the back of the dinette on 2300 so I didn't bother with it.) Found the source for swivel base on this forum. Easy to install. Added less than an inch to height of seat.
Bill, did you use the one from Discount Van and Truck?
Snowman9000 is offline   Reply With Quote
Old 01-13-2014, 08:20 AM   #62
Yes that was the one. Easy to install, comes with high grade bolts. Better with two people simply to handle the weight of the seat. The activator level sticks out the front between passenger legs. It was too long. Easily cut off with hacksaw and added a plastic cap to it ("screw protector at Home Depot") to cover sharp end. It is easy to rotate with door open. A little tight but possible to rotate with door closed.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 01-13-2014, 09:13 AM   #63
thanks Bill! I was concerned about how close the "house" cutout is going over and besides the seat, wondering if it made the seat too confined once it is swiveled. But I think I'll go ahead and order it.
Old 01-28-2014, 07:45 PM   #64
We got a good look at the gutter draining above the cab door thing today, when we went thru a truck wash. Thanks to this thread, I was able to slide into the door without out filling the map pocket with water runoff. It seemed like maybe a 3" extension would make a fairly big difference in how far the door could be opened?
Old 01-29-2014, 03:30 PM   #65
Took delivery one week ago. Living room 42" TV does not work. On four door fridge, right door does not latch. I will need to take it in to dealer to fix when the parts come in.
gsevilla is offline   Reply With Quote
Old 01-29-2014, 04:03 PM   #66
Is the TV a Jensen 12V? If so, check the cigarette plug adapter. If the light isn't on the plug, it's burnt out. I go through about one a month (or each trip).
4Gcampers is offline   Reply With Quote
Old 01-29-2014, 04:41 PM   #67
It is a Jensen. I'll check that when I get home. Thanks for the tip.
Old 01-30-2014, 08:20 PM   #68
GM
bclemens's Avatar
The 42" TV is not 12v. Too big. The 32" are all 12v however.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 01-31-2014, 01:42 AM   #69
doctinker's Avatar
4GCampers , is it the plug or the fuse that burns out? Does this TV draw too much for the circuit? Do you think there is a fire risk?
doctinker is offline   Reply With Quote
Old 01-31-2014, 10:49 AM   #70
I checked the back and found the power plug wires to the TV are spliced with wire caps. The wires run into the cabinet so I couldn't see where they go. I also noticed there's a 12v plug on the outside of the cabinet (next to the cable tv plug) that is not being used.
Another thing I noticed is that there's a blue light that comes on when I press the power button on the TV, the screen flashes for a second, and then goes dark. So there seems to be power going to the TV.
And finally, the same TV is mounted on the outdoor entertainment center and it works perfectly.
Conclusion: Bad TV? or Bad wiring?
sunseeker
