Old 07-12-2013, 02:23 PM   #21
Originally Posted by ATVer View Post
Sounds like you have a leak in one of your jack systems. Leaks are not that uncommon as I have had 2 fitting leaks already. If you can't see any thing leaking externally then you have an internal leak in one of the control valves.
Yes, sewer hookup is a pain especially if you have the small hole in the compartment. I believe there was a running change in 2013 to a larger one.
You will find a lot of construction debris in any areas that are not easily visible. Take a look under your slides. I had reason to open the cab foot wells to run my satellite radio cable and found sharp debris (staples, brads, cut metal etc) mixed in with the wiring. I then went thru the whole coach removing panels and got almost half a gallon bucket of junk.
I just got the Sirus cable and was wondering how to run it and attach it? Would appreciater your help.
jtrippy is offline   Reply With Quote
