Old 11-15-2015, 09:33 PM   #1
lakewood90's Avatar
Sunseeker Rear Bumper & Hitch Height
We have a Sunseeker 3010DS on order due to be delivered in the next week, and would like to know what the measurement from the center of the hitch to the ground is and also the measurement from the bottom of the rear bumper to the ground. We are replacing a Coachmen Freelander 3150SS with the new unit. We are towing a Honda CRV and also plan to install a new rock guard of some type on our new unit.
I realize that the measurements could vary an inch or so, depending upon the air pressure in the air bags.
Thanks in advance for any input.
lakewood90 is offline   Reply With Quote
Old 11-18-2015, 07:17 AM   #2
Sorry for the delay in posting. My hitch is 16" and the bottom of the bumper is 20"
GJones is offline   Reply With Quote
Old 11-18-2015, 11:20 AM   #3
lakewood90's Avatar
Smile Thanks GJones!
Thanks for the reply. I am trying to purchase a couple of things for the MH before it arrives and didn't want to purchase wrong. We are taking it south for the winter soon after it arrives and have a small window of time to get everything changed over and leave.
After taking the old one to Alaska this past spring/summer I wanted to be certain I had a new rock guard installed before leaving. I also needed to know if I will have to alter my hitch/towbar setup.
Thanks!
Old 11-18-2015, 04:25 PM   #4
I love my 3010. Leaving in it again Sunday. I hope you enjoy it.
Old 11-19-2015, 07:20 PM   #5
what do you use for a rock guard?
Mark1 is offline   Reply With Quote
Old 11-19-2015, 09:15 PM   #6
I use a Blue Ox KarGuard II. Hooks right on tow bar and rolls up when not in use.
Old 11-19-2015, 10:35 PM   #7
lakewood90's Avatar
I have been using the Demco solid deflector that mounts on the tow bar and also had the IBC splash stop guard on the trip to Alaska. The IBC unit was too low and I think it was to blame for the CRV becoming so filthy in spite of washing it every chance I had during the trip.
Since this is a new MH, I am probably going to order the smart solutions rock solid unit at http://www.amazon.com/Smart-Solution...=rv+rock+guard although I have heard a lot of good things about the Blue Ox unit that GJones is using. If I knew that I could adapt the Blue Ox unit to my Demco tow bar, I might try installing it on mine.
I camped next to a Class A in Valdez that was towing a CRV and the front end was being held together with duct tape. The windsheld was cracked in several places, all headlights and fog lights were damaged, and the rest of the car was going to have to be refinished. All due to the solid rock guard being mounted too close to the ground and kicking up gravel and stones, so I am just a little leery of them. The owner said that once someone pointed out the problem, he suffered no more damage after raising the guard to the recommended 4" height above the ground. Of course, by then it was probably too late to see any new damage.
Old 01-23-2016, 06:32 PM   #8
Navy Junior
SunSeeker 3050's Avatar
New Tow'd
I'm going to pull a new Jeep Compass (4 down) using a road master Falcon 2 and wonder if I would benefit from the solid rock deflector under my Sunseeker 3050 and something mounted to the jeep as well? I have the standard mud flaps behind the dualies, but I suspect they are just not enough. Any thoughts?
SunSeeker 3050 is offline   Reply With Quote
Old 01-25-2016, 02:59 PM   #9
Boso's Avatar
My car gets filthy when being towed by my 3050 with stock mud flaps. This problem never existed on my pushers with full flap all the way across the back maybe 2-3" off the ground. Did buy a bra one time to put on accru mdx but it wasn't needed. Vehicles all stayed clean.
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 01-25-2016, 03:02 PM   #10
Boso's Avatar
That 4" may be correct also I didn't install come from factory with them already mounted.
hitch, sunseeker
