Old 01-05-2015, 03:23 PM   #1
Boso's Avatar
Sunseeker side view camera
How do you remove moisture fom the inside on side view cameras it is there every time it rains or is it something dealer should do its a new 2015 3050s dealer didn't fix last time had dried out by the time they looked at Thanks Boso
Boso is offline   Reply With Quote
Old 01-05-2015, 03:32 PM   #2
Good question , I have the same thing, is yours on the left side or both?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 01-05-2015, 03:48 PM   #3
Boso's Avatar
Side view cameras
Both my cameras fog up but not the back it is clear as it can be I do use my side cameras when they work maybe somebody will have the right answers Boso
Old 01-05-2015, 05:30 PM   #4
tmhyer's Avatar
I think they meed ro ne replaced under warranty. There should not be condensation inside the lenses
tmhyer is offline   Reply With Quote
Old 01-05-2015, 05:31 PM   #5
tmhyer's Avatar
I meant need to be
Old 01-06-2015, 03:22 PM   #6
Definitely sounds like replacement is needed. We have a 2014 Forester 3051S and haven't had any problem.
SkipnTerri is offline   Reply With Quote
Old 01-06-2015, 04:18 PM   #7
Boso's Avatar
Side view camera
Rained Saturday 0% visibility Monday 100% clear Tuesday I don't understand how it clears that fast from0% to 100% clear Boso
Old 01-06-2015, 04:53 PM   #8
Wondering if the seal isn't tight. It fogs up easily and clears once there's air movement -- just like a windshield.
Old 01-06-2015, 05:28 PM   #9
Boso's Avatar
That very well could be but how do you get into the case that holds the lense seal I m sure I could figure out but don't want to ruin warranty if it is more complicated than I think it is
Old 01-06-2015, 06:23 PM   #10
Can you create the same 'problem' rain makes by using a water hose? Was the temperature warm or cold during the rain? The dealership will have to replace the seal or the whole mirror, because it can't be good for the camera for this to be happening.
sunseeker
