Old 07-28-2015, 04:55 PM   #1
Suspension air bags
I have a 3050s sunseeker. I was wondering what psi everyone sets their air bags at?
Jtf320 is offline   Reply With Quote
Old 07-28-2015, 05:05 PM   #2
That is like getting (NASCAR) to give up their setups! Every driver/load setup is different! Start at 30PSI! Youroo!!
Old 07-28-2015, 06:14 PM   #3
I have mine set at 55 but not because I know anything about it. The instructions with it said to set it as low as possible but no lower than 20 psi.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 07-28-2015, 06:22 PM   #4
I run mine about 65 psi. The higher you go the less sway you have, however it'll rattle your teeth out of your head if you're in the back. Basically the higher the pressure the better to handle however the rougher for the ride.
The Real Snowman is offline   Reply With Quote
Old 07-28-2015, 06:27 PM   #5
dcheatwood's Avatar
Usually around 45
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 07-28-2015, 07:07 PM   #6
Average Joe
MrJoe's Avatar
I found 60 is the sweet spot on ours.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 07-28-2015, 07:11 PM   #7
We set ours at 65 and feel considerable stability improvement.
SkipnTerri is offline   Reply With Quote
air bags, suspension
