Old 11-10-2014, 10:37 PM   #11
Originally Posted by bclemens View Post
I am told it is not a problem...apparently it is designed that way. I sent this up the river to the engineers at Bargman basically saying I was tired of the complaints. They call it a "drain and dry" design. They say if they seal it and water does infiltrate, then the water has no place to drain.
Reminds me of a joke I heard years ago....Engineers design it...common folk make it fit or work! LOL
grumpyer is offline   Reply With Quote
Old 11-11-2014, 07:38 AM   #12
Engineers design what works, purchasing agents buy what's cheapest, then marketing sells it for slightly less than the good design.
Then engineers get blamed because the designed-to-a-price junk fails.
Retired engineer
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 11-11-2014, 07:55 AM   #13
Originally Posted by RvBill3 View Post
The LED conversion is a great solution to the problem after-market. Could Bargman produce a product that could be used as an original install? I switched to LEDs as a safety factor. Almost got rear-ended on Interstate when stopped for crash. Car turned at last second and ended in the ditch beside my passenger door. The LEDs are 10 times brighter than the incandescents that come on the MH. The LED backup lights are also very bright which is great for backing into campsite in the dark. (See my pictures posted above.) 100% Correct! LEDs so (The OTHER GUY) can see YOU! Youroo!! PS and the LEDs are Totally sealed/No Water!
2012 Forest River Sunseeker 2300 Chevy
OK!
Old 11-11-2014, 08:23 AM   #14
Retired engineer
Very true.
Another retired engineer.
Old 11-11-2014, 08:51 AM   #15
Infractee
Spurious logic...
If it is sealed, water can not infiltrate, if it was not possible to properly seal a lens housing then every car going down the road would look like it has 2 red fish tanks in the back.
As for the lens filling up from condensate... sealed lenses would also solve this problem. All those clear lenses were all chinese crap with phony DOT labels. They were sealed as well as a submarine with a screen door.
RhoZeta is offline   Reply With Quote
Old 11-11-2014, 11:53 AM   #16
GM
bclemens's Avatar
Preaching to the choir. I am already looking for other options.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 11-11-2014, 06:44 PM   #17
wesslvm's Avatar
I put a strip of black electrical tape under the lens cover and over the raised edge of the lamp base to help form better seal. Worked like a charm.
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 11-12-2014, 12:47 PM   #18
Did you have the urge to strangle them?
If they are a "drain and dry" design why do they do neither? Then every year you also need to remove the lens and wash them (don't forget to dry them) as they fill up with dirt and further cloud the lens. What a crock. I know you need to be PC but I don't.
And it is great that you spend time here to help. Thank you!
RedRollingRoadblock is offline   Reply With Quote
Old 11-12-2014, 12:50 PM   #19
GM
bclemens's Avatar
You read my mind. I had 20 samples of tail lights in my office the day after I got their email.
Old 11-12-2014, 12:59 PM   #20
Average Joe
MrJoe's Avatar
You can add mine to the list. I keep a supply of bulbs in the glove box....
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
light, water
