Forest River Forums
Sunline User Photos
Old 08-10-2011, 01:06 PM   #1
popbreed's Avatar
tank level indicators
Can someone explain the operation of the tank level lights on the panel. Is the lowest level "switch" on the tank hooked to chassis ground and the remaining "switches" will complete the ground circuit when the tank "contents" reaches their level to the lowest "switch"? I have the 1/3 light on the black tank on when the tank is empty. Understanding the circuit would enable me to do a bettered job trouble shooting. Thanks for the help.
popbreed is offline   Reply With Quote
Old 08-10-2011, 02:34 PM   #2
Moderator
You could just have some paper hanging on the sensor, giving you the false reading. I can dump at home, so I fill the tanks till 2/3 full, then wait 2 days or so, and drain. Usually clears the problem. You might get one of the tanks cleaning wands and have a go at it that way.
Windrider,
Too many toys, not enough time.
2001 F150 SuperCrew
2002 Jeep Wrangler
1978 Cessna 152
2000 Honda 750 Nighthawk
2008 Work and Play 18LT
windrider is offline   Reply With Quote
Old 08-10-2011, 02:34 PM   #3
cfsoistman's Avatar
You have it right. There could be a little TP connecting the 1/3 probe to the the bottom probe lighting the 1/3 light. A build up of debris can do the same as well. Those probes are not real accurate. The grey tank indicators are a bit more reliable due to less debris in the tank but over time if they get a build up they'll read wrong as well. The best I've seen are the Horst Miracle Probes. Much more accurate than the stock probes.
Horst Miracle Probes for Wastewater Tanks in Recreational Vehicles RVs
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 08-11-2011, 12:30 AM   #4
flyrotor's Avatar
Ditto to the previous responses, also, remember the best way to read the lights, empty is when you get lucky enough that nothing is hung up in there, 1/3 is "not empty" 2/3 means it's time to dump if you can, Full... it might not flush any more.
2011 Dodge 2500 CTD, Crew Cab, 169" WB, 6-speed man
2008 FR Wildwood 23 BHLE
Nights camped in 2011:20
Nights camped in 2010: 21
flyrotor is offline   Reply With Quote
Old 08-11-2011, 07:47 AM   #5
Lou Amadio
herk7769's Avatar
The 1/3 light is "Not Empty"
As you can see from the photos, the "ground" for the lights is at the same tank level as the 1/3 light. ANY water, sludge, or slime remaining in the tank will complete the circuit and turn on the "not empty" light.
The 2/3 light is 1/2 tank
The "full" light is about 7/8 full.
Will post links for you.
Watch this video:
http://www.miracleprobes.com/buy.php
Your wiring diagram and trouble shooting guide are also attached.
Horst Miracle Probe 5th Wheel Install #1
Is how I repaired mine.
File Type: pdf Micro Monitor Panel Troubleshooting.pdf (149.2 KB, 15 views)
File Type: pdf KIB Monitor Panel M21 Wireing Diagram.pdf (51.2 KB, 13 views)
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
herk7769 is offline   Reply With Quote
Old 08-11-2011, 07:54 AM   #6
Lou Amadio
herk7769's Avatar
Another photo that shows the relationship of the probes.
DO read my install post for why the stock probes suck.
Old 08-11-2011, 03:37 PM   #7
popbreed's Avatar
Thanks everybody for your help. Herk, the links were great and your explanation super. This wonted I am going to switch to the Horst probes in both the black and gray tanks. Fortunately, (or maybe unfortunately) I do not have to deal with the plastic bottom cover. I have contemplated adding an alum. frame work and insulation to enclose the 2 tanks. As in your case, the bottom two are nearly at the same level. My probes are a different design and have a screw terminal in the center. I may just leave those probes in place and add new holes for the Horst probes and move the second probe up the tank an inch or more. However, can you clear this point. I assume the bottom probe is the ground connection to the panel. If so, how does the empty LED light Separate ground in the control panel? The placement is inaccurate because both tanks have a low sump on the empty end and yet the probe placement for the top 3 probes in nearly equally spaced. Thanks again for the help.
Old 08-11-2011, 08:09 PM   #8
Lou Amadio
herk7769's Avatar
Ok, there is a single probe left of the dump valve (the "ground") and three probes to the right of the dump valve (the 3 light "hots").
When the water level "shorts" the two lowest probes, the 1/3 light comes on. As the water level rises it adds the resistance from the next probe in line and turns the 2/3 light on. when it reaches the top probe all 3 lights will be lit.
oh, and the "empty" led is the "power on" indicator. It lights as long as power is available to the display.
Old 08-11-2011, 10:31 PM   #9
Bill_C's Avatar
Tank level indicators
Has anyone tried the SeeLevel tank level sensors? There are no probes. The sensor sticks onto the side of the tank and uses the original wires to the panel. It gives a read out in percentage, not thirds. At least this is what I read about them.
DRINK COFFEE--do stupid things faster and with more energy !
Bill_C is offline   Reply With Quote
Old 08-12-2011, 06:53 AM   #10
Lou Amadio
herk7769's Avatar
Bill,
I don't recall anyone posting recently. I would love to hear about their results as well.
» Online Users: 582
104 members and 478 guests
0721SSROO, 09grizzly1, 2007Rockwood2601, 4Jeeperz, 4tonns, austincpr, bean, Bearcat55, Bigjimt, bignugget, BlakeB, bob34787, Bob_Loblaw, bouldercamper, brandon0214, brookside, Buster1281, Cafjackracing, caper, Cascade Bob, CHD Dad, chevy02, chof16, cyclepuck, dansa122, darkcloud, dasimser, deerslayer, DGrissom, dimurrrw, djorgensen3, DonG, donn, dsdaniels, dunnnc, Emptypockets, Flying dutchman, Ga.Lineman, Great Horned Owl, HAARubicon, Hob, HockeyDad217, Iggy, irish01, Jack67, jaxfl, jdefeo1, JDWeir, Jeep4Two, JeffK, jes520, kamp k, ldmcmahan, LeadPoop, LFugate, lindy, lisalynn48, micalo, mike1329, milw156, mlhalter, mn_guy, mrdon003, mtnguy, Pa-cj5, papap, ParrotHead, Patrick29, pg_rider, pixleys, PrairieBoy, punkaccountant, rdwin, rgmiller32, ROCKIN 34, ronhanson, Rugged Brown, RV Guy, RV Van, rxfiller, SabreSam, sail2liv, schrederman, sellis1053, Skippkon, snowbrid, Stank Bait, Steve7575, stevem4134, superk1035, tedstr, Tee, terryh, TheFlagGang5, TheSasks, toclark491, tonybab, travyp, Triguy, Twinbluelake, vp22er, Waterfowlwarrior, wolfpack21643, woodsman
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
