Old 09-24-2018, 08:46 AM   #1
Frankie Z's Avatar
Tank sensors
Gray tank sensor showing empty on panel when obviously, full any suggestions (i.e.is there a fuse I should be checking)?
Frankie Z is offline   Reply With Quote
Old 09-24-2018, 09:16 AM   #2
cavie's Avatar
it happens to everybody. No fix short of installing new ones on the outside of the tank.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 09-24-2018, 09:23 AM   #3
Shredder's Avatar
Does it show on the other levels? 1/4 1/2 3/4?
is it only not working when its completely full or are all the settings not showing?
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
Old 09-24-2018, 09:25 AM   #4
Mr. Dan's Avatar
It doesn’t happen to everyone that a sensor shows a tank empty when it’s full. The normal flaw is showing full when it’s empty. I suspect you have a bad connect to the bottom sensor (ground/base) so that the other higher sensors are not completing the circuit. We had a thread on this recently (can’t find it on my phone - will look again later).
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 29; booked = 12
Old 09-24-2018, 05:24 PM   #5
Duckogram's Avatar
Maybe this one?
RV tank sensors not working at all
ILB
Old 09-24-2018, 09:18 PM   #6
Frankie Z's Avatar
Old 09-24-2018, 09:21 PM   #7
Frankie Z's Avatar
Thanks to everyone who took the time to reply. The other lights, Propane battery fresh water all seem to be working just the gray.
All input is greatly appreciated, when I get back from trip I will put advice to work.
tank
