Old 11-14-2013, 01:19 PM   #1
Mike & Molly's Avatar
Tech Question ?
For outside winter storage I have removed the coach batteries, & store them in my basement on Battery Tenders.
My question is, - Can I run/exercise the generator with out the coach batteries hooked-up. Will it effect the wiring, fuses, breakers or the converter at all.
I'd like to be able to run the generator once a month but don't want to re-connect the coach batteries every time. Can I run a few ceiling lights?
Any info would be appreciated.
Mike & Molly is offline   Reply With Quote
Old 11-14-2013, 02:00 PM   #2
papap's Avatar
I would think you would be find doing this. Just make sure the battery cables can not touch each other or the frame.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 11-14-2013, 05:47 PM   #3
Will you be able to start the generator without the batteries?
DSurette is offline   Reply With Quote
Old 11-14-2013, 05:56 PM   #4
I agree with DSurette, I would think you would need 1 battery installed to start generator unless there is a way to use the coach battery.
Rzbot is offline   Reply With Quote
Old 11-14-2013, 06:04 PM   #5
papap's Avatar
Would think so. LOL
Old 11-14-2013, 07:40 PM   #6
Yes, you can start the generator without coach batteries. It won't hurt anything in the coach. The generator just sends 110 volts to the convertor and to the breaker panel. If there are no batteries, the convertor just doesn't have to put out as many amps to the 12 volt system.
You just start the engine and that gives power to the generator's starter. I have done it when my coach batteries were run down too low to start the generator.
Be absolutely sure the coach battery cables are insulated, because the cables will be energized.
Load the generator to 50% of its rating if you can. A portable electric heater is just right.
Old 11-14-2013, 09:07 PM   #7
Chassis alternator I believe is rated at 200 amps which may or may not be enough to start the generator without anything from battery. The generator manual may say how many amps are needed. Also I don't think it will put out 200 amps at idle so you may need the V10 up at a couple thousand RPM. You also may be able to use the battery tie switch under the drivers seat to connect the chassis battery to the generator. However I don't know if that circuit will work without the chassis battery installed. Maybe I can find time to review the electrical circuit diagrams tomorrow and determine what will work.
Finally if you are going to leave the chassis battery in during storage why take out the coach batteries. Running the chassis engine and generator will keep the coach battery charged and they won't deteriorate anymore than the chassis battery will if you keep it in during storage.
ATVer is offline   Reply With Quote
Old 11-14-2013, 11:48 PM   #8
wesslvm's Avatar
On my unit I have started the generator with the battery disconnect in off, it cranks off the same battery as the vehicle. No power will go to the coach batt cables with the disconnect in off.
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 11-15-2013, 03:22 AM   #9
I leave both batteries in place and start engine and generator about once a month. If you are going to start generator anyway (a good idea) why not just leave the battery in place? I load the generator while exercising by starting the heat pump. No sense sitting in the cold while I'm running the genny.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 11-15-2013, 06:50 AM   #10
Why don't you fog the genny, drain the carb and you won't have to exercise it at all. I have been doing this since I got the genny. About 4 years now. Get the spray fog, remove the air filter, start the genny and then spray the fog into the air intake until the engine stalls out. Then drain the carb. I take the battery out along with the 2 house batteries and put them on smart chargers. The genny is a 4000 watt Onan which is called a juice box. It goes into the trailer hitch at the back of the 5er.
Here's a site for this one. Not the one I use but it's an example. AMSOIL Engine Fogging Oil
Pipeman is offline   Reply With Quote
