Old 02-09-2018, 07:52 PM   #1
Television hook up
In my Sunseeker 3050 there are two TVs, front and back. The back seems to be hooked to the outside cable only and the front to the King Digital Antenna. How can the front be hooked to the pedestal cable connection?
Bob meyer is offline   Reply With Quote
Old 02-09-2018, 07:59 PM   #2
sgtlm17's Avatar
First when using park cable ensure your power booster is off. Then in TV settings ensure TV is set to cable then run a channel scan.
If this is a new rig and you have checked the above you need to check wiring connections at the power booster.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 02-09-2018, 08:25 PM   #3
Power booster? Is that controlled by the button inside the cabinet? What is the other cable receptacle for inside the cabinet?
Old 02-09-2018, 08:28 PM   #4
sgtlm17's Avatar
Yes the power booster is a little button on the plate that lights red or green. It needs to be OFF when using park cable. The connection all by itself is probably your satellite connection that comes from the roof
2011 Jeep JK Toad
Old 02-09-2018, 08:56 PM   #5
I don't have a satellite. I'm still wondering what that might be. Talked to the dealer which is like talking to a 3rd grader about higher physics. Basically no clue.
Old 02-09-2018, 09:02 PM   #6
sgtlm17's Avatar
Very simple the white plate is your booster. Light on is over the air antenna. Light off is park cable which you connect to side of rig. The brown plate with the male connection is a wire feed to your roof. It allows you to connect a satellite dish on roof. All the wiring is already installed. You would connect your satellite box to the brown plate.
Then an hdmi cable from satellite box to the female hdmi brown plate above the white plate.
2011 Jeep JK Toad
Old 02-09-2018, 09:51 PM   #7
That seems to make sense. I'm shock that Forest River had the foresight to prewire the coach for satellite. I had visions of duct tapeing a cable down the side and punching out a window. Thanks alot, you have been a great help.
Old 02-09-2018, 09:53 PM   #8
Now that I think of it. Where is the satellite hook up on the outside?
Old 02-09-2018, 10:02 PM   #9
sgtlm17's Avatar
It's on the roof Generally it is right in front of the ac unit near the right under a blob of dicor
2011 Jeep JK Toad
Old 02-09-2018, 11:40 PM   #10
I'll look for it next time I'm up there. Thanks again
television
