Old 03-29-2019, 06:19 AM   #1
testing switch
Wondering if someone has a video of how to test a rocker switch on a motor home. My switch has one black three white and one red wire not sure how to test this is an electric awning power switch on a 2013 sunseeker 3050s
oldnewguy is offline   Reply With Quote
Old 03-29-2019, 07:05 AM   #2
Lacey's Spring, AL
formerFR's Avatar
why, what is the symptom that makes you think something is wrong with it?
formerFR is offline   Reply With Quote
Old 03-29-2019, 08:21 AM   #3
bubbles's Avatar
Not sure of what version of awning switch you have but what the switch does is supply 12 volts and ground to the awning for one direction (extend) and reverses the 12 volts and ground to the awning for the other direction (retract). Some switches have the jumpers (metal straps) for this already installed and some switches require wire jumpers be added.
Old 03-29-2019, 09:34 AM   #4
Head Rambler
Here's a schematic of how those switches work. As Bubbles said, Some have pre-installed straps and some use wire jumpers.
Gotta go campin!
Old 03-29-2019, 09:50 AM   #5
See Bama Ramblers pic. Put your voltmeter across the top two connections to the motor. Rock the switch. You should see +12VDC when you push the rocker one way and -12VDC when you push it the other way, and 0VDC when it's in the middle.
This assumes you have battery voltage to the switch. Here's a video on measuring voltage:
You can do a continuity check by setting your meter to resistance and checking across each set of pairs of connections, but if you do this, you need to disconnect all the wiring from the switch so you don't measure the resistance back through the wires. ALSO - take a pic or write down which wire goes where before you remove them.
Here's a video on measuring resistance:
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 03-29-2019, 09:58 AM   #6
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
As Rockfordroo pointed out selecting your meter to do resistance (ohms scale)- the ohms scale does not like voltage, and you will blow the internal fuse or fry the meter if it is a really cheap one.
Nice picture of the switch wiring Bama Rambler.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
switch
