Old 11-02-2014, 04:34 PM   #1
Thermostat Problem
The thermostat in our 3170ds will not let use increase the setting past 32 degrees? Does anyone know why this is happening? The furnace heat comes on and it is warmer than 32 outside.
colestat is offline   Reply With Quote
Old 11-02-2014, 04:51 PM   #2
davel1971's Avatar
is it Celsius? That would be 90 fahrenheit
David & Lynn
Old 11-03-2014, 09:10 AM   #3
Mike & Molly's Avatar
Check the settings
X2 That.
The thermostat can be programed to read in Celsius.
Forgot how to check/change that setting but the web site for that model has instructions.
Mike & Molly is offline   Reply With Quote
Old 11-04-2014, 07:32 PM   #4
I made this mistake also. If you hold down the + and - buttons at the same time and hold it will switch back to Fahrenheit.
beachbum107 is offline   Reply With Quote
Old 11-05-2014, 07:58 PM   #5
wesslvm's Avatar
Agree with above answers, most likely cause.
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
thermostat
