Old 02-20-2018, 07:42 AM   #1
Tire air pressure
We have problems getting to the stems, on the tires, to put air in our MBS Sunseeker. Looking for suggestions, and what air compressor you suggest to carry with you. Thanks in advance!
sunseeker56 is offline   Reply With Quote
Old 02-20-2018, 05:25 PM   #2
Duckogram's Avatar
Unless the compressor cannot produce enough pressure to fill your tires, it is unlikely that is your issue. Instead, look at truck air chucks for a solution. Also consider using alligator caps which have double seals and do not need to be removed to air up your tires.
ID:	162959   Click image for larger version
ID:	162960   Click image for larger version
ILB ( | )
Old 02-20-2018, 07:15 PM   #3
Empty Nesters
KenandCarol's Avatar
I have a Ford E450 Sunseeker and I got a dually air chuck like Duckogram posted a picture of. Very straight long stem for the back rim and an angled port for the front rim.
I got a Viair 400P-RV for my portable compressor. It runs off of 12 V so I just connect it to my house battery,
2017 Sunseeker 2250 24' MH
KenandCarol is offline   Reply With Quote
Old 02-20-2018, 08:46 PM   #4
Thanks! We never heard of an alligator caps? We will look into that.
Old 02-20-2018, 08:50 PM   #5
I am checking Amazon for the Viair 400P-RV. Never heard of chuck like Duckograms either. I could see picture if you posted but will try to find online. Thanks for the help!
Old 03-19-2018, 09:56 PM   #6
Sophomore Campers
Do you take off the short valve extenders installed from the factory when using a chick like the one above?
2017 Sunseeker 2860DS
MizzouMan_2000 is offline   Reply With Quote
Old 03-20-2018, 05:45 AM   #7
Duckogram's Avatar
If you are asking me, I do not have any valve extenders however I have a TireMinder Smart TPMS so my valves have transmitters on them. To check pressure, I look at my phone. Adding air requires transmitter removal which requires wheel cover removal to reach the inners. Then I use the straight 7” air chuck pictured above. You do not need to remove valve extenders to use the air chuck.
ILB ( | )
Old 03-20-2018, 06:38 AM   #8
Sophomore Campers
The extenders that come from Forest River are nearly useless as they aren't long enough to clear the hub caps. If I have a suitable air chuck maybe I could take off those extenders and would be easier to air up the tires??
Old 03-20-2018, 06:58 AM   #9
Duckogram's Avatar
Can’t argue that. The inner extension were plastic and would not support my TM transmitters. The outers had metal 135* that did not leave enough room for the transmitters. If you are going to use the long air chuck, you do not need extenders however I do suggest that you use alligator caps rather than nothing.
Edit: Just noticed that you have a Chevy. Everything I mentioned may not apply.
ILB ( | )
Old 03-20-2018, 07:47 AM   #10
Sophomore Campers
Yeah I think both the inner and outer extenders are metal on mine. Do the alligator caps work with screw on tpms?
pressure, tire
