Old 06-23-2019, 12:02 AM   #1
damccarthy's Avatar
Tire replacement for 32' class c
Hello. Looking for advice on the best RV tires for my 32' Sunseeker Class C. Getting ready to replace my 2 front tires. Thanks!!
>Dave
damccarthy is offline   Reply With Quote
Old 06-23-2019, 05:31 AM   #2
NH Maple Maker
russhd1997's Avatar
Make sure that the load capacity or load range rating meets or exceeds the ones that are on there now. If possible match the ones that you have on the rear.
I just put BF Goodrich tires on my TV because they were the only ones in my size that were LT tires. The BF Goodrich tires are made in the USA by Michelin.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
russhd1997 is offline   Reply With Quote
Old 06-23-2019, 06:54 AM   #3
My 2018 3010DS came with Korean Hankook tires. After 9000 miles, I'm very satisfied with their performance...very smooth and quiet ride.
GMax is offline   Reply With Quote
Old 06-23-2019, 08:28 AM   #4
I put the Firestone Transforce tires on my 32 footer - replaced all 6. These are standard on most ambulance vehicles which also carry some weight. 2 years and about 8,000 miles, no problems at all.
rgthoma is offline   Reply With Quote
Old 06-23-2019, 07:06 PM   #5
Take the longway home's Avatar
Replacement tires
I replaced all 6 tires on my 28 ft. Sunseeker with Michelin LT in March before Florida trip.. Drove through snow and rain I'm very satisfied with the performance .
Take the longway home is offline   Reply With Quote
Old 06-23-2019, 09:05 PM   #6
oldsmasma's Avatar
Our 28’ Lexington came with Michelin’s. They were from the run that were recalled. They were replaced free of charge. Very pleased all around.
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
oldsmasma is offline   Reply With Quote
Old 06-23-2019, 11:47 PM   #7
Senior Members
Butch & Lena's Avatar
>Dave
We just replaced all 6 Michelin LT tires with the same. They were 5 years old and I was not going to take any chances with tire problems with tires that were beyond their life of bearing 5 years of heavy weight. I believe all tires should be replaced at the same time. If not that then at least the same type tires that are already on the MH. Hopefully they are LT's also.
2015 3010DS Sunseeker
2010 Jeep Wrangler Unlimited
Butch & Lena is offline   Reply With Quote
Old 06-24-2019, 09:14 AM   #8
Last season I replaced all 6 with Michelin Defender LTX, which replaced the old LTX and am very happy. On my last rig, I used Firestone Transforce HT's which were fantastic...probably safe to assume the HT2 (which replaced the old HT) will perform as well.
Just make sure whatever you use, they're Load Range E.
rad_jr is offline   Reply With Quote
Old 06-24-2019, 12:54 PM   #9
Goodyear G949 tires are heavy duty and used in commercial applications. I have 4 of them on my 3100 Sunseeker. They weigh about 10 pounds more than the LTX tires they replaced. Ride is ok. They are quit every pricey, though.
ActionJackson is offline   Reply With Quote
Old 06-24-2019, 01:23 PM   #10
Shredder's Avatar
Check the make of your tire and the DOT number online. I had all 7 of my tires replace for free from michelen becuase of a recall.
It might save you 2500 dollars
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
class c, replacement, tire
