12-04-2015, 05:21 PM
Tire rotation
Wondering if anyone rotates there tires on there Sunseeker I have never rotated tires on my RV's before might try on this one it has about 6000 miles on now would be time
2015 sunseeker 3050s. 2007 saturn aura
12-04-2015, 05:39 PM
Hey Boso , if you are going to rotate tires keep in mind the direction they have been rolling,you are going to have to bring six tires into a four tire position, sounds weird I know, the first movement could be left rear outside to right front, and right rear outside to left front, next rotation you could do a left front to left rear inside, and right front to right rear inside. just keep track were you are in the rotation process. Good luck. Maybe someone else has a better idea!
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
12-04-2015, 05:50 PM
If I was going to rotate them I would move the tires from the rear axle to the front on the same side then the front to the back.
12-04-2015, 05:55 PM
Hey Ford , We are talking about six tires on a sunseeker, it has dual rears. You shouldn't move the outside rears to the front on the same side , you are changing the direction of rotation of the tire.
2014 Forester 3051s
2012 Sonic toad
12-04-2015, 06:13 PM
I doubt the tires are directional so it is of little consequence.
The two inside on the rear HAVE been turning in the same direction as the steering tires so if you go from front to back on the same side direction of rotation is the same.
12-04-2015, 06:17 PM
Hey Ford, reread second part of my original post, thats what I said about the inside rears going to the front.
2014 Forester 3051s
2012 Sonic toad
12-04-2015, 06:25 PM
Then we must agree to agree, no?
12-04-2015, 06:26 PM
Correct sir.
2014 Forester 3051s
2012 Sonic toad
12-04-2015, 07:05 PM
I guess what I have seen is the inside rear go to the front same side outside rear move to the inside rear and the front goes to outside rear same side boy after that last drink I'm confused now
12-04-2015, 07:31 PM
Check your owner's manual and also your tire manufacturer's recommendations.
Our MBS 2041 has a very specific regimen for tire rotation in the owner's manual. It is switch front with rear inside, same side, and switch rear outside with rear outside on the opposite side (so those two change turning direction).
However, the text contains a little qualifier: "DUAL TIRES AT THE REAR: If your vehicle is equipped with tires of the same size, the tires on the front axle can be rotated with the inner tires on the rear axle in pairs so that the intended rotation (spinning) direction of the tires remains the same. If the tread pattern on the tires is not unidirectional, the outer tires on the rear axle can be rotated from one side to the other." [underlining added]
It does not say what to do if the tires are unidirectional, but presumably in that case you would rotate the three on the same side in a circular pattern, just be sure to go clockwise or counter-clockwise each time or you will (too quickly) end up back where you started.
12-04-2015, 07:41 PM
I've owned 3 Class A diesel pushers, a Class B Sprinter based, and 8 different trailers of various sizes and shapes. I have never rotated the tires on any of them! Why, simple answer-- it's because time will get them before mileage accumulates to the degree that it wears them out. I'm a firm believer that rv tires need to be replaced every 5-6 years of the manufacturing date unless, of course, the tires get worn out due to mileage. Very few of us put the number of miles on our rv 's in 5-6 years to wear out the tires so rotating them to get "extra mileage" out of them is a waste of time and money to me.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
12-04-2015, 09:01 PM
Hey Boso Have another drink, forget about the tires , get the cameras and the air bags fixed
2014 Forester 3051s
2012 Sonic toad
12-04-2015, 09:05 PM
The bottom line is, the front tires are going to get the most wear with the twin I beam suspension that Ford E-450 uses, so if you want to rotate just go inside rear dual to the front and front to the inside rear on the same side.
2014 Forester 3051s
2012 Sonic toad
12-04-2015, 10:41 PM
They are supposed to be fixed picked up yesterday then dropped off at Ford shop for state inspection and a few other things while I was on that side of town guess I will get back next week and install reflex steering stabilizer take one more short trip and have a oyster roast in myrtle with camping buddies then winterize and cover until March and already had that drinksss
12-04-2015, 10:45 PM
Hey stang I had airbags fixed counter top replaced cameras replaced storage bay seal replaced and sealed am I forgetting anything
12-05-2015, 11:26 AM
Dual tires should have the same tread depth (or as close as possible). If not the tire with the most tread left can get overloaded as it is "higher".
Most with dual rear wheels don't bother to rotate, unless they get too much curb rash. Then they just rotate inner with outer on same side (assuming tread is bi-directional).
2011 Sunseeker 3170DS - 30,000 miles explored
12-05-2015, 12:20 PM
I think I agree not to rotate unless nessasary I have never put over 24000 miles total on a Rv yet before I traded are sold
12-05-2015, 01:30 PM
I always just left the rears alone on my 2004 Winnebago and just changed sides on the fronts for more even wear. I originally added the spare in and rotated them in a circle. If you check the Michelin site, they just swap sides on both front and rear. As mentioned, they don't wear out they die from old age and ozone cracks. Here's the site, look at the duals alternate rotation-
Tire Rotation | How often should I be rotating tires? | Michelin US
Also, there are no directional arrows on my tires Michelin 225/75/16 LRE M+S2.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
12-05-2015, 04:05 PM
Like funfinder said...if you do decide to rotate, CHECK YOUR TREAD DEPTH! I was going to rotate mine (just over 21,000 miles now)...was surprised to find that while the outside of the fronts were visibly worn, the center of the front tires had significantly more tread than the rears. In that case, if I rotated them, the tire that came from the front would likely be overloaded on the inside rear position, since it's overall circumference would be greater than the tire beside it. Decided to leave them alone and have another beer!
12-05-2015, 05:26 PM
2012 Solera
Had some alignment related edge wear on the front tires. Alignment shop - after aligning - recomended putting both right rears on front (outer to left front, inner to right front) and both fronts on right rear. Tread depth ~ matched (both fronts showed similar wear), nice square and matched tires on front, no change of direction of rotation on any of the tires. Now, about 15000 miles later, all tires look good (since alignment fronts staying nice and uniform; worn fronts have "squared up" on right rear position). If I rotate again, I will put the left rears on the front, fronts on left rear, and leave the right rears alone.
JLeising
2012 Solera "S"
Calif SF Bay Area
