Old 12-04-2015, 05:21 PM   #1
Boso's Avatar
Tire rotation
Wondering if anyone rotates there tires on there Sunseeker I have never rotated tires on my RV's before might try on this one it has about 6000 miles on now would be time
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 12-04-2015, 05:39 PM   #2
Hey Boso , if you are going to rotate tires keep in mind the direction they have been rolling,you are going to have to bring six tires into a four tire position, sounds weird I know, the first movement could be left rear outside to right front, and right rear outside to left front, next rotation you could do a left front to left rear inside, and right front to right rear inside. just keep track were you are in the rotation process. Good luck. Maybe someone else has a better idea!
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 12-04-2015, 05:50 PM   #3
Ford Idaho's Avatar
If I was going to rotate them I would move the tires from the rear axle to the front on the same side then the front to the back.
Old 12-04-2015, 05:55 PM   #4
Hey Ford , We are talking about six tires on a sunseeker, it has dual rears. You shouldn't move the outside rears to the front on the same side , you are changing the direction of rotation of the tire.
2014 Forester 3051s
2012 Sonic toad
Old 12-04-2015, 06:13 PM   #5
Ford Idaho's Avatar
I doubt the tires are directional so it is of little consequence.
The two inside on the rear HAVE been turning in the same direction as the steering tires so if you go from front to back on the same side direction of rotation is the same.
Old 12-04-2015, 06:17 PM   #6
Hey Ford, reread second part of my original post, thats what I said about the inside rears going to the front.
2014 Forester 3051s
2012 Sonic toad
Old 12-04-2015, 06:25 PM   #7
Ford Idaho's Avatar
Then we must agree to agree, no?
Old 12-04-2015, 06:26 PM   #8
Correct sir.
2014 Forester 3051s
2012 Sonic toad
Old 12-04-2015, 07:05 PM   #9
Boso's Avatar
I guess what I have seen is the inside rear go to the front same side outside rear move to the inside rear and the front goes to outside rear same side boy after that last drink I'm confused now
Old 12-04-2015, 07:31 PM   #10
MNtraveler's Avatar
Check your owner's manual and also your tire manufacturer's recommendations.
Our MBS 2041 has a very specific regimen for tire rotation in the owner's manual. It is switch front with rear inside, same side, and switch rear outside with rear outside on the opposite side (so those two change turning direction).
However, the text contains a little qualifier: "DUAL TIRES AT THE REAR: If your vehicle is equipped with tires of the same size, the tires on the front axle can be rotated with the inner tires on the rear axle in pairs so that the intended rotation (spinning) direction of the tires remains the same. If the tread pattern on the tires is not unidirectional, the outer tires on the rear axle can be rotated from one side to the other." [underlining added]
It does not say what to do if the tires are unidirectional, but presumably in that case you would rotate the three on the same side in a circular pattern, just be sure to go clockwise or counter-clockwise each time or you will (too quickly) end up back where you started.
MNtraveler is offline   Reply With Quote
tire
