Old 08-09-2015, 08:10 PM   #21
geezer with gadgets
757Dave's Avatar
Tireman9,
thanks so much for checking this out for me. Without your help I would've just purchased something thinking I had the correct item and been frustrated when I couldn't get it to work. You don't know how much I appreciate your effort.
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 48
757Dave is offline   Reply With Quote
Old 08-09-2015, 08:40 PM   #22
benagi's Avatar
Originally Posted by Tireman9 View Post
Probably yours are "non pressurized" extenders
Mine look just like the ones in the photos above by Sage. They must be pressurized I would think. You just push the chrome looking ball on the end of the stem on the outer tire a little and air comes out. On the inner tires, I have to use a small screwdriver and push the ball way down before I hear air coming out. Using my air compressor at home, I have no problem putting air in the front tires, the outer rear tires but I can't get any air pressure reading or add air to the inner tires.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 08-10-2015, 02:51 PM   #23
Commercial Member
Airless or pressurized hose
OK found the answer (right under my nose)
Wheel Masters has
short hard extenders.
Stainless pressurized hose kits and "Airless" hose kits
Just pay attention to the part number
The "Airless" would be non-pressurized extenders with the internal actuator rod.
I am thinking that if you are having problems adding air or getting a pressure reading you have "Airless" extender and it needs adjustment or you need different chuck or gauge that pushes the rod deeper.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 08-10-2015, 03:46 PM   #24
benagi's Avatar
Wheel Masters has
That makes sense. I think you are right when you say the internal actuator rod is not making contact soon enough for my chuck to work on the inner tires. Now I need to find out if they are adjustable. These are brand new and installed either by Ford for FR. Our coach came with those on our tires when it arrived from the factory in June of this year.
1968 tent trailer
1985 Jamboree 23 ft
Old 08-10-2015, 05:26 PM   #25
Sagecoachdriver's Avatar
Are the schrader valves tight especially the one on the extension? One of the extension I bought from CW had that problem and the other leaked. I tried using another air hose and got it to work. I fill mine at home with a big air compressor. One hose has the chuck and the other doesn't. I don't recall which worked on it and I bought the Borg extensions shortly thereafter back in 2012. No problem since.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 10 trips 32 nights
Sagecoachdriver is offline   Reply With Quote
Old 08-10-2015, 05:29 PM   #26
trdutch's Avatar
How I did itClick image for larger version
Name:	ImageUploadedByForest River Forums1439245734.989228.jpg
ID:	85287Click image for larger version
Name:	ImageUploadedByForest River Forums1439245753.071456.jpg
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 08-10-2015, 06:37 PM   #27
geezer with gadgets
757Dave's Avatar
Thanks Tireman9 and trdutch. This information is great. Now I just need to get the parts ordered.
Old 08-10-2015, 08:22 PM   #28
benagi's Avatar
Did a little more investigating on the problem of getting air into the inner tires. Figured it out. The inner workings of the valve stem on the outer tires are near the surface and easy for any chuck to depress it. They are also all metal short J extenders. The inner valve stem extenders are rubber and the pin you have to depress looks to short. One of two things, replace the inside with longer stem or get a special chuck that can reach that far in. Also, all the valve stems have the following caps on them, so you don't have to remove them to fill your tires. see photo. Thx for all the replies.
1968 tent trailer
1985 Jamboree 23 ft
Old 08-11-2015, 07:46 AM   #29
trdutch's Avatar
Tire Valve Extenders
That extender (cap) you show a picture of was the culprit in all my fill and leak problems
I got rid of them and my troubles went away
After I put my set up on I just used regular caps that came with the braided line kit
Before the braided set up mine leaked and at first I thought they were part of the stem cause they in turn had caps on them
When I realized they actually were caps (they look like a fillable stem after all) but I too couldn't get them to take air.
had no use for them.
Added the braided extenders on to the blank basic stock stems (used the 90 for the outer tire stem that faces inward so my braided line didn't kink and called it a day.
This unit can sit for months with very little pressure change, in fact I haven needed to add air since June and that was a couple pounds in one tire
'78.....tents
Old 08-26-2015, 07:35 PM   #30
benagi's Avatar
OK, I'm back with some more info on the problem of filling and checking tire pressure on the inner tires of our MH. I went to the auto parts store today and bought a truck air chuck and a regular chuck. Neither one will reach or depress the valve core to let air in (see following pic). Also, looked for longer valve cores, but they only had one size. I thought they made longer ones, so they would be closer to the top of the valve stem. Wonder how they filled the tires in the first place. Probably before they put the extenders on. Would like to fix the original rubber extenders that were put on by Ford or FR, if not, guess I'll have to spend the bucks on some new ones as suggested in previous post.
1968 tent trailer
1985 Jamboree 23 ft
tire
