Old 08-26-2015, 08:34 PM   #31
dan-nickie's Avatar
I had that problem until I finally found this:
http://www.amazon.com/Milton-S693-Du...ruck+air+chuck
Dan
2014 Berkshire 390RB-60
dan-nickie is online now   Reply With Quote
Old 08-26-2015, 10:32 PM   #32
benagi's Avatar
I have one of those but when pressed against the valve stem, it still won't depress the valve core.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 08-26-2015, 10:43 PM   #33
Commercial Member
If you have tried a couple different pressure gauges or air chucks and can't depress the valve core then I suspect the core was installed too deeply in the stem and needs to be replaced with a new core.
The pin on a valve core should be about flush with the outer end of the stem.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 08-26-2015, 10:44 PM   #34
dan-nickie's Avatar
Dang it. Good luck.
Dan
Old 08-26-2015, 10:51 PM   #35
benagi's Avatar
Tireman, that is exactly what I have been trying to say. The valve core is to deep on both sides. All the outside tires are just fine. Surprised no one else has had this exact problem. Like I said before, I think I'm going to have to replace those extenders that came with our coach if I want to add air or check tire pressures myself.
1968 tent trailer
1985 Jamboree 23 ft
Old 08-26-2015, 11:29 PM   #36
2012 Solera
If the extenders that came with the Motorhome are the Air-Flexx airless extensions used on the Solera, several of us have solved the problem by cutting off one end or the other of the plastic threads on the extender - see this thread: http://www.forestriverforums.com/for...ure-45973.html
Good luck!
Jim
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 08-27-2015, 11:59 AM   #37
Citrus County, Fl.
GL1800Rider's Avatar
I had an issue getting air into the right inside dual. Took it to the local tire shop and the tech tightened something and was able to add air. I have not tried it since but will be checking the air in a couple of days before I get fuel ( waiting for the price to go down a bit more)
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 08-27-2015, 03:38 PM   #38
Commercial Member
Many times people do not understand how tire valves work. If there is a valve core leak simply cranking down on the valve core may actually make things worse as the sealing surface is not like a water faucet.
I have a post on my blog "Why do Valves Leak" in Nov 2 2012 that covers this in detail. Info on my blog in my signature.
Old 08-27-2015, 05:13 PM   #39
JimOneil43's Avatar
TPMS507 & Extenders?
So, if you need extenders and also want the tpms507RV system with flow thru sensors, what goes on first? The extenders and then the TPMS?
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 08-28-2015, 02:18 PM   #40
Commercial Member
Don't think it makes any difference as long as the outer end of the hose is firmly mounted. Firmly means bolted down not held in place with springs or rubber bands.
tire
