Old 01-04-2015, 12:31 PM   #1
JimOneil43's Avatar
Tires on Sunseeker
Can anyone tell me what type and make of tires are supplied as original equipment on Sunseeker? I've seen a lot of posts here mostly from owners of travel trailers regarding the load rating and lack of quality on their tires. Planning on a purchase of Sunseeker MH and am concerned if the tires we end up with are less than a good quality. Also, what mileage can you expect with them on a 31' MH? Don't want a major expense for tires right away after new MH purchase. Also, does FR offer any options on tires on a new unit?
JimOneil43 is offline   Reply With Quote
Old 01-04-2015, 02:25 PM   #2
Tires
Mine came with Michelin LTX 16" tires. Balance is perfect.
2015 Sunseeker 3050s
15 Years Full Timing
Now own Sticks and Bricks
J. V. is offline   Reply With Quote
Old 01-04-2015, 03:03 PM   #3
Hoglou's Avatar
Tires
Generals E series on the chevy 4500.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 01-04-2015, 04:11 PM   #4
Ford E450 2014 3010DSF
Michelins
Kevin & Judy is offline   Reply With Quote
Old 01-04-2015, 04:13 PM   #5
The tires on a new Sunseeker should not be a problem for either wear or failure, regardless of the brand.
Michelins were originally installed on the Ford year model 2010 chassis of our Sunseeker 3100, which was built August, 2010 as a 2011 model. Luckily for me those tires were recalled by Michelin about two years ago and I got a full set of 7, including the spare, new at no cost. They had about 24,000 miles on them and had enough thread to go at least that many more miles. One of the regular posters on this forum has a tire shop and he said an industry newsletter stated about 300 of the tires lost threads. That's out of a total of over 1 million. To me that says they were quite unlikely to give a problem on any one vehicle.
Of course, Michelin corrected the problem, so I don’t worry about the replacements.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 01-04-2015, 04:38 PM   #6
JimOneil43's Avatar
Tires on sunseeker
Of course, Michelin corrected the problem, so I donít worry about the replacements.
Thanks RamblerGuy for the info. Makes me feel much better. I have always considered Michelin as a top of the line tire, so I can quit worrying.
Old 01-04-2015, 05:07 PM   #7
Tilly's Avatar
My 2012 2400 on Chevy 4500 has Uniroyal Lorados. I've got over 30K on them and only slight uneven wear on front - realignment should help them last another 15-20K
2013 Sunseeker 2300
Chassis: Chevy 4500
Toad: 2004 Shadow Aero
"On the Road" since 8/8/12
Every Day's a New Adventure!
Tilly is offline   Reply With Quote
Old 01-04-2015, 05:39 PM   #8
There's no guarantee that your chassis will have Michelins.
You could make it part of the deal that if it doesn't have Michelins, but another new one on the lot has them, have the dealer swap them before you close the deal. It wouldn't cost the dealer much and you'd just be letting someone else drive on the other brand.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 01-09-2015, 09:38 PM   #9
Bus Driver
Deaver's Avatar
Mine came with Michelin LTX 16" tires as well. You want to make sure they are "E" rated tires
Deaver is offline   Reply With Quote
Old 01-10-2015, 12:40 PM   #10
Same experance as RamblerGuy for our 2011 3170DS, except we DID have a tread separation and blowout while passing slower traffic on I-10 in Texas traveling 70mph.
This was during our Christmas travels of 12/13. Michelin had just issued the recall 2 weeks earlier and letters hadn't even made it out to owners yet. I was one of the first to get 6 new tires at zero cost to me. We were at around 26,000 miles when we had the blowout and all 6 tires where replaced. By my estimates the current tires were at about 50% of their life.
Michelin did us well and I have no complaints. The RV industry suggests replacing your tires every 5-7 years regardless of miles. Unless you are a full timer, you'll replace due to age before mileage.
Also, let me add that I remember our tires being dated 2009, as the Ford cab was built in early 2010, then Forest River finished it mid 2010 as a 2011 year model. So, our tires where already over 4 years old and 26,000 miles so Michelin made it more than right per my view.
2011 Sunseeker 3170DS - 30,000 miles explored
funfinder5 is offline   Reply With Quote
sunseeker, tire, tires
