Old 05-21-2019, 07:26 PM   #1
To caulk or not to caulk...that is the question!
So I notice in my SS shower that where the shower panels meet the shower pan at the bottom at the seam there is no caulk. Now, I'm sure in a home there would be a caulked seam there. Is there anything different in a SS? I'm tempted to go ahead and run a bead of silicone over the seam but I thought I'd ask the pros on this board first.
Thanks!
2014 Sunseeker 3010DS on Ford Econoline E450 Chassis
Newly Retired!!!!
Atlanta Panther is offline   Reply With Quote
Old 05-21-2019, 10:32 PM   #2
A32Deuce's Avatar
That is ok. The pan sides are up under the side walls. The water will come out the door opening before leaking at the top of the pan. That's how it is in mine. No caulk needed.
A32Deuce is offline   Reply With Quote
Old 05-22-2019, 06:45 AM   #3
Gumpster808's Avatar
Yep ours in our Forester is the same - loose between wall and pan. No issues in last two years weve had it.
Should be fine - designed that way but compared to the house, you are correct, it does look strange and concerned me as well initially.
Lynn & Dennis
Nights Camped 2017 - 35 / 2018 - 15
2014 3051S - First RV for us
2018 Hyundai Elantra Sport Toad
2015 Harley CVO (retirement bike )
2015 Challenger ( Wife's Toy)
Gumpster808 is offline   Reply With Quote
Old 05-22-2019, 07:56 AM   #4
What about at the top of the shower wall? Should there be a gap or should it be tight to the wall? Thanks
2019 Sunseeker 3010ds
SunseekerFAMof6 is offline   Reply With Quote
Old 05-22-2019, 08:12 AM   #5
A32Deuce's Avatar
Ours is tight at the top.
Old 05-22-2019, 08:17 AM   #6
Ok thanks. Guess i have to make a warranty call. Ugh.
Old 05-22-2019, 08:27 AM   #7
Bill and Gail's Avatar
Mine had a bead of caulk at the top
Bill and Gail is online now   Reply With Quote
Old 05-22-2019, 09:22 AM   #8
A32Deuce's Avatar
X2!
Old 05-22-2019, 09:31 AM   #9
CentralMePistol's Avatar
I questioned this during my PDI...
I was told to NOT caulk at the bottom. It is intentionally left open so that any condensation/moisture that may build up behind the shower wall can get out. Makes some sense to me and haven't had any issues with it left as is.
AND, it does make sense that if water were to get behind somehow that it needs a way out or could quickly become a much bigger problem.
2018 Cherokee 274DBH
2012 GMC Sierra 1500
4x4, Crew Cab, 5.3 KDL HD Cooling, 3.42 ratio
Recurve R6 WDH w/Sway Control & SumoSprings
Days Camped:2019-18 and counting / 2018-30
CentralMePistol is offline   Reply With Quote
Old 05-22-2019, 07:32 PM   #10
Send a message via MSN to Tiggerdad
Shower walls on mine are slightly wavy so they are not tight. Other than cosmetic it serves no purpose to be tight and/or caulked.
If you caulk, do not use silicon, won't stick long
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
caulk
