08-20-2019, 01:39 PM
Fathermo
Toad question
I know there are variables, however, can anyone be so kind as to give me an estimate of the Toad vehicle weight I could be looking at for a 2020 Sunseeker 2440DS?
Dry Sunseeker.
Thank you for your help.
Michael and Carolyn
2020 2440 DS
08-20-2019, 02:28 PM
On the forest river website it says the GVWR is 14500 and the GCWR is 22000 so your towing capacity is probably around 7500lbs. Hope that helps.
2019 Sunseeker 3010ds
08-20-2019, 02:53 PM
Bet it is a 5,000 lb hitch though.
2015 335DS
08-20-2019, 03:00 PM
If it is the Chevy then yes but the Ford e450 is 7500lb hitch.
08-20-2019, 04:37 PM
Fathermo
7500
Michael and Carolyn
2020 2440 DS
08-20-2019, 04:39 PM
Fathermo
Thank you so much for your quick reply. I thought it was in that area. I didn't have the two numbers readily available at the moment. I guess I should have maybe gone to the site, but your help is appreciated.
Michael and Carolyn
2020 2440 DS
08-20-2019, 05:43 PM
Originally Posted by Fathermo
7500
Impressive!
Now let's hear from some of those no TOAD braking system guys with a GVWR of 14,500 and a GCVW of 22,000 or more than 1/3 of the total weight on the towbar.
2015 335DS
08-20-2019, 06:25 PM
Fathermo
Impressive!
Really?
Michael and Carolyn
2020 2440 DS
08-20-2019, 06:37 PM
Really?
In other words...get a braking system for your TOAD.
2015 335DS
08-20-2019, 08:51 PM
Fathermo
In other words, Really.
Michael and Carolyn
2020 2440 DS
08-21-2019, 08:03 AM
I have the same year, model, and chassis motorhome as Fathermo, the original poster. The hitch on the motorhome is rated to tow up to 7500 pounds according to the label on the hitch. Further, the Ford chassis GCWR of 22,000 pounds will allow the full hitch rating to be towed.
You lost the bet. Posting answers that are just bets or guesses are not really helpful.
08-21-2019, 08:15 AM
I suggest that you get a little experience before you decide what is helpful and what is not. Obviously a problem that can be resolved from posted specs is not really an issue that will generate a lot of confusion. Of course, I could have looked it up myself, before posting which I usually do.
Some problems are not so easily resolved...
2015 335DS
08-24-2019, 09:57 PM
A bit of history. Ford chassis Sunseekers built before 2015 have the same tow capacity but the hitch is only rated at 5000#'s. 2015 and newer have a tow capacity of 7500#'s. I believe the difference is the thickness of the safety chain loops on the hitch.
As far as auxiliary braking for toads, most if not all states require brakes on toads/trailers above 3000#'s. Check the state regulations you plan to tow in.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
