08-17-2018, 09:03 PM
#61
Originally Posted by Duckogram
I tow a 2011 Smart Fortwo. It has been to 48 States, over 30,000 miles towed.
It weighs 1,410 lbs, gets 40mpg (91 octane) and does not require a supplemental
braking system except in Manitoba Provence. It dinghy tows and my DW hooks it up
by herself in 5 minutes. We use a battery disconnect switch for safety. The lights are
wired to work off the coach plug. And the best part; When we go out to dinner with
friends, they drive!
Edit: New 2800QS tomorrow. Will tow Smart home.
Question is there anything else besides the battery disconnect involved with towing the Smart Car? I just bought one and looking for advice.
08-17-2018, 10:33 PM
#62
Certified Curmudgeon
The switch is the only add-on specified in the owners manual.
Mike Dropped
08-17-2018, 10:41 PM
#63
Senior Member - Retired
I tow a Smart Car. I installed a battery cutoff switch slightly under the dash on the passenger side so I can reach it while sitting in the driver seat preparing the Smart Car for towing. I elected to add a secondary braking system. Be sure to use a bungie cord to keep the steering wheel orientation correct while towing. Necessary due to the vehicles light weigh front end.
This is a link to a previous discussion of Smart Car four down towing
http://www.forestriverforums.com/for...-a-109666.html
John & Gloria Hunsaker FROG Member CA-0030-988
2014 Georgetown XL 334QS (class A with 4 slides)
2013 Smart Car TOAD
Blue Ox Aventa LX tow bar, base plates, diode kit
SMI Stay-IN-Play Duo auxiliary braking system
25' Off shore blue water fishing boat
08-17-2018, 11:01 PM
#64
I dont use a bungee. It’s not that I would not like to but I have the Pure which has a different steering wheel. So I put up with the steering “hunting” for straight. That only happens when you are turning sharp then the front wheels go through the transition of a driveway or damaged pavement on a sharp right turn. It’s very noticeable. All I have to do is stop. Then it straightens out when I restart. It can be a bit awkward in traffic.
Mike Dropped
08-18-2018, 06:31 AM
#65
I would check the dinghy towing guide for your year smart car to verify. I read that the new ones are no longer towable 4 down.
2014 3051S - First RV for us
08-18-2018, 10:13 AM
#66
Very frustrating finding a TOAD that can carry 7 people. The list is getting smaller and smaller. I saw one of the new Traverse and was disappointed to find it is no longer rated to be towed. I do not want to pull a full sized SUV but it is looking like that is becoming my only choice.
2014 Sunseeker 3170DS
08-18-2018, 10:28 AM
#67
I think you are right. We tow a 2013 Buick Enclave. Heavy, but comfortable for 7 even with bags. 2008 through 2017 Tow flat...but not the 2018 model!
2015 335DS
08-18-2018, 12:19 PM
#68
Tow a 2 seater and let your buddy with the exxon valdez drive to dinner. Then you can partake in the festivities.
Mike Dropped
08-18-2018, 01:14 PM
#69
A friend tows a Flex. We tow a Miata...
08-19-2018, 08:16 AM
#70
I think the main problem with the new vehicles is the 6-9 speed transmissions they are starting to use for better MPG. They are not mfg to handle being towed.
08-19-2018, 11:22 AM
#71
You may want to search CL or other sites for good used with towable capability.
Example: we found our 3 yr old Jeep Liberty on Craigslist with 8.007 original miles. It was a true old lady story. She bought it new, then found out she couldn't drive any more. The car had everything we wanted along with the new car smell.
08-21-2018, 08:50 PM
#72
Our toad is a 2014 Ford Edge. It is so comfortable and love using it as an everyday car. Easy set up too.
08-25-2018, 12:55 PM
#73
We tow a 2016 Jeep Compass behind our RV. It’s a manual transmission so nothing needs to be done other than put it in neutral. Beware, Jeep changed the transmission mid-year. The newer version of the compass can not be flat toad.
08-25-2018, 03:34 PM
#74
Retired and Loving Life!
I flat tow a 2007 Jeep Grand Cherokee, automatic, 4X4. I already had the Jeep when I purchased the Forester; however, when it gives out, I will probably buy another. We love the Jeep. Great ride and versatile. Jeep has 170,000 miles on it, and has been towed 21,000 more. Recently took a 8,500 mile cross country trip with no TOAD problems. It has an electronic switch that disengages the transfer cases. Love it.
08-25-2018, 07:40 PM
#75
We currently have a travel trailer, but if we do get a MH, i have this for our toad. This has been my hunting vehicle for the last 10 years, I love it! 1991 Suzuki Samurai.
Terry and Laurie
2017 Flagstaff 27RLWS
2020 F-350 7.3 Godzilla 10 speed 4X4 CCLB
