Old 06-22-2014, 08:44 PM   #1
everik3006's Avatar
Toilet flush
The pressure to the toilet is very very reduced. All facets are working well and pressure is normal. Please help me, do you have any suggestions. ? I have a sunseeker 3170Ds
everik3006 is offline   Reply With Quote
Old 06-22-2014, 08:56 PM   #2
VinceU's Avatar
Cutout pressure to your FW system. Place a towel under the toilet supply connection. Remove connection and carefully inspect the inlet to the operating valve. Chances are its full of debris from the builder. Cleanout, reconnect and you should be in business.
Old 06-22-2014, 09:05 PM   #3
everik3006's Avatar
Thanks, how cutout the pressure for FW ?
Old 06-22-2014, 09:20 PM   #4
abjb's Avatar
Turn the water off to your MH.
Then flush till no water flows.
Put a small bowl under the water connection at the toilet to catch the remaining water.
Disconnect the water line at the toilet, you shouldn't need any tools.
I use a paper towel and a small screwdriver to remove the debris from where you disconnected the hose, be careful not to damage the screen inside the flush valve.
ab&jb
2012 Georgetown 360
SHE wanted "a new motorhome"
abjb is offline   Reply With Quote
Old 06-24-2014, 08:40 PM   #5
everik3006's Avatar
Toilet flush
Big thank you from me and my family !!!! For me, the residu (debris) is like a limestone !
Old 06-24-2014, 08:52 PM   #6
VinceU's Avatar
DIY- Sure beats a trip to the dealer! Glad to hear it was that easy.
Old 06-24-2014, 08:55 PM   #7
everik3006's Avatar
I like DIY !!!!
