Old 10-26-2013, 03:32 PM   #1
tow button
Should you drive with the tow button on? I have read different explanations.
Rob Stewart is offline   Reply With Quote
Old 10-26-2013, 03:35 PM   #2
If you are towing something. GM recommends it for towing anything according to my manual.
Old 10-26-2013, 03:39 PM   #3
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Ford recommends it too.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 10-26-2013, 03:49 PM   #4
I mean should we be deiving with it on all the time. We have a 2013 3170 with the Ford v10
Old 10-26-2013, 03:53 PM   #5
Only if you are towing something.
Old 10-26-2013, 03:53 PM   #6
Lloydg's Avatar
Use the tow feature only when you're towing. Your Ford owners manual explains this is more detail.
Old 10-26-2013, 03:58 PM   #7
Ok....thanks
Old 10-26-2013, 04:13 PM   #8
B47
X2. - and not sure on Fords, but our Ram also has an Exhaust Brake function (button) that is used along with the Tow function.
Old 10-26-2013, 04:53 PM   #9
The Tow button locks out the OverDrive gears of most transmissions. When pulling a load the OverDrive gears will heat the transmission up, the internal parts of the OverDrive portion are not designed to do much beyond save fuel on the highway. I know in my gasser especially turning turning off OD with my 5th wheel is pretty much a must anyway as the motor needs the RPM to be able to eat properly and enough to tow comfortably.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 10-28-2013, 08:51 AM   #10
GM
bclemens's Avatar
I use the tow haul, even when not towing when I am descending a steep grade. let's the engine do the breaking. I also use it in tight city traffic so its not always shifting.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
