Old 02-15-2018, 12:54 PM   #1
Tow dolly vs tow bar
I have a 2017 2800qs and am wanting to get a toad. I would like to hear from people using a dolly such as a demco kar kaddy ss. It seems most people are using tow bars ,but, a dolly allows a vastly larger car types to be used as a toad. Are there any other advantages of a dolly and is there a better dolly than the demco kar kaddy ss?
Tom C 47 is offline   Reply With Quote
Old 02-15-2018, 01:22 PM   #2
I do both types of toad, or no toad, depending on where we are going, and who is going.
Jeep TJ, flat tow.
Acme Dolly for our "regular" vehicle.
Sometimes no toad at all.
Yes, the flat tow is a bit quicker to hook and unhook, but sometimes we need to bring our car. In our case, DW does not drive the Jeep (manual trans), nor can we take dogs and DD in the Jeep (not enough room in the back for two big dogs and DD), so sometimes we take the car. The Acme does not take more than a few minutes longer to hook or unhook, at least how I set it up (safety cables from dolly to car are vinyl covered cable, which loop through the car wheels). I can move the dolly by hand, and, if needed, can hook it to the car. At home, the dolly stands on end, against the house, out of the way. I can stand it up by myself, and have even done so at a campsite (strap to tree or RV for safety).
So my opinion is to pick the vehicle(s) you want to bring, within the limits of your RV (don't forget the weight of the dolly), and use whatever means needed. In the grand scheme of things, having the toad to fit your needs far outweighs the method of towing.
One caveat though. If you use a dolly, you are likely limited by the dolly tires, to 65mph. If you flat tow, then you are limited by the RV tires (probably 75mph). If you prefer to travel faster than 65mph (I normally do not, towing or not), then flat tow will give you more MPH before exceeding the tire safety limits (assuming proper inflation etc.).
Flat tow requires setting up a braking system, at least a break away, if not for the law, then for (what used to be more) common sense. Dolly can include a breaking system.
FWIW, I "grew up" with surge brakes, so both my setups are surge. I did setup an electronic controller, in case I have to tow someone else's rig, but it was a controller I already had for another purpose, since I was already running wire for indicator lights for the toads... (wire from toad brake light switch to led in cab).
2016 SS 2250 E450
Dp26 is offline   Reply With Quote
Old 02-15-2018, 02:39 PM   #3
Acme tow dolly is what I use
I do not even know it is there unless I look in the rear view camera. Just make sure you do not forget it is behind you. Avoid u turns or backing up situations. You can back up a little with the tool provided to keep the surge brakes from activating. Always preplan your route when towing a dolly. The dolly tires are only 12 inch rims but are 10 ply load range E and good for 75mph.
Retired Chief USN
2017 Sunseeker GTS 2800
charles l is offline   Reply With Quote
Old 02-15-2018, 03:29 PM   #4
Empty Nesters
KenandCarol's Avatar
I have just ordered the ACME EZE Tow Bar after research and inputs from this site. I am anxious to get it set up and head out to Oregon at the end of March. I am getting it because the toad I want to use is not compatible with 4 down towing and the cost of getting a tow set up. The ACME tow bar looks like the best solution for us.
We are new to the RV world and while taking our local shakedown trips we realized that we wouldn't want to go on a long trip without the flexibility of taking another car along.
2017 Sunseeker 2250 24' MH
KenandCarol is offline   Reply With Quote
Old 02-15-2018, 03:39 PM   #5
Jane1550's Avatar
We use a dolly for our Versa, Spousal Unit stated "If sumptin happens to that P.O.S., we'll leave it where it died"
Jane1550 is offline   Reply With Quote
Old 02-15-2018, 06:56 PM   #6
Duckogram's Avatar
What Dp26 said.
ILB ( | )
Old 02-15-2018, 10:46 PM   #7
I, too, thought long and hard about which method to choose. At the end I decided to tow 4 down mainly because I didn't want to worry about storing the dolly or having it stolen.
I use the Ready Brute Elite tow bar which once set-up is fairly easy to install and uninstall and it's stored in the back of the CRV.
Stan
2015 Sunseeker 2300 Chevy
swuebbels is offline   Reply With Quote
Old 02-16-2018, 02:39 PM   #8
I tow 4 wheels down. My first Dinghy was a Wrangler and it simple and didn't even know it was back there. Now we tow a Chevy Equinox 4 wheels down. Easy and quick to hitch and unhitch. Personally I don't want to deal with a tow dolly at home or a campsite. Don't want to deal with strapping it on in the rain with muddy tires. If I get into a tight spot, quck to unhitch the dinghy and backup the motorhome. A dolly is get the car off, unhitch the dolly then re-hitch and put the car back on. I guess I'm too lazy LOL. MY VOTE 4 wheels down.
hupmat is offline   Reply With Quote
Old 02-16-2018, 03:02 PM   #9
I have been using a karkaddy 3 for 5 years. Towing my Cadillac SRX behind a Sunseeker, Georgetown & now a pusher, in all cases it has performed very well. It handles corners very well and the surge brakes also are nice. I also like the 14” wheels. That said I have had cracking issues with the plastic fenders and had to replace fender lite housing. If I had to buy another dolly I would choose karkaddy.
IMSMan is offline   Reply With Quote
Old 02-16-2018, 03:50 PM   #10
I've used both- Demco kar kaddy advantage as you have stated is more car choices- For me the disadvantages were loading- especially if wet and crawling under car to hook up safety chains I always worried about about straps on tires loosing for me- a real pain ! . Went with tow bars much easier to hook up and much higher confidence but still took some time.
Went to a 5er and never looked back.
ksmith954 is offline   Reply With Quote
