Old 07-06-2015, 12:53 PM   #11
Advantage of tow haul is better shifting at low speeds and helpful downshifting when braking down hills. I also lock out 6th gear (overdrive) when towing heavy.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 07-06-2015, 12:56 PM   #12
Tow haul keeps the engine in its power curve better and helps to better slow down because the transmission down shifts more aggressively. Always use it if you are hauling that is why they put it there.
walljammer is offline   Reply With Quote
Old 07-06-2015, 01:32 PM   #13
AKA: 'tiredTeacher
awellis3's Avatar
Many of these computerized trannies "learn" how you drive. Tow/haul off, they "think" you are going around as you usually do without the trailer so they operate as a daily driver. Once you push tow/haul, the tranny thinks "Aha! I'm pulling a trailer now, so my master will be accelerating and breaking differently."
So it's not 100% factory presets. The tranny knows how you drive in tow/haul.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 07-06-2015, 02:15 PM   #14
Increased fluid flow?
Originally Posted by mark0224 View Post
You can turn it on and off as needed, if you get into a hilly area it would be wise to turn it on. One of the Tow Haul functions is to increase the amount of transmission fluid flowing through the transmission cooler keeping your transmission cooler. Yes you can make the engine work the transmission similar to the Tow Haul and on the long flat it would work but in hills your transmission gets a workout and the increase flow of transmission fluid will save on repairs.
Exactly how does this increase the transmission fluid flow? Never heard of this.
fbconsults is offline   Reply With Quote
Old 07-06-2015, 02:15 PM   #15
Originally Posted by gmacklem View Post
When I was towing my travel trailer with my F-150, I turned overdrive off. But now with the Sunseeker, I am getting ready to tow a Honda CRV. Should I have tow/haul mode on or off for towing with a class C?
Thanks.
Greg
They have a tow/haul on there for a reason. With today's computer driven vehicles, the dealer can tell if you towed with out it on and let's say you burn up a trans, it's on you if they can prove it and want to prove it. I use it because it was made to use when you are towing or hauling heavy loads. I've seen a lot of remarks over the years about the tow/haul mode, I don't understand why you wouldn't want to use it. Saving a gallon of gas (if it saves any at all) versus a new trans, I'll pay for the gas.
Stovebolt is offline   Reply With Quote
Old 07-06-2015, 02:29 PM   #16
I did a test while towing to see what the mpg difference was with tow haul on and off. Result - no difference. Always use the tow haul on when towing.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
BusyRetirees is offline   Reply With Quote
Old 07-06-2015, 04:11 PM   #17
plshilo's Avatar
My button is Always On whenever we are towing....Doesn't matter about the gas, easier on transmission and engine.
Phil & Linda and our two four legged girls - Cricket & Lucy
2016 F350 Super Duty
2011 Prime Time 27.0 RET Crusader 5th Wheel
plshilo is offline   Reply With Quote
Old 07-06-2015, 04:26 PM   #18
Oaklevel's Avatar
Not trying to be smart but it says it is a Tow/Haul mode so it is for when towing & hauling. Why would you not use it????? If it was not for that, it would be a not for tow / haul mode ??? It is there for a reason......
Yes I use it.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 07-06-2015, 04:52 PM   #19
Old Timer
Originally Posted by Yorkranchgalnguy View Post
I do better with my foot and the tach. My husband loves it! So, to each his own.
X2, don't see any reason to keep revving the engine when I could be running one gear up already. Going up a little nudge will downshift at just the right time without lugging the engine. Nothing like seat of the pants driving -- just takes 45 years of experience.
kentnjudy is offline   Reply With Quote
Old 07-06-2015, 06:50 PM   #20
I use it when towing mostly because of the downshift function. What I find annoying is how long it takes to upshift! I accelerate nice and easy...when I'm driving my motorhome, I'm not in a hurry...but this thing wants to redline before it shifts to the next gear, like I have my foot on the floor. I find myself backing off the pedal until it upshifts, then accelerating normally again...that V10 doesn't exactly sound like it likes to rev. More annoying is that it "surges" as I accelerate with a steady foot on the gas. Without the tow/haul mode on, it upshifts more quickly and accelerates smoothly. I'm assuming this is all normal....
rad_jr is offline   Reply With Quote
modifications
