Old 07-08-2018, 09:07 PM   #1
Towing a full size Pickup
Hey everyone,
I currently tow a Jeep Grand Cherokee behind the motorhome (3010 DS) with no problems. It weighs 5000 lbs.
Has anyone ever towed a full size pickup behind your Sunseeker/Forester?
I own a 2016 Dodge 1500 Ecodiesel. It weighs about 5800 lbs. My Sunseeker is rated to tow 7500 lbs and I have the 7500 lb hitch.
So just looking for thoughts and any experiences.
Thanks!
MikeRP is offline   Reply With Quote
Old 07-08-2018, 09:30 PM   #2
Duckogram's Avatar
How close are you to your GCWR?
ILB ( | )
Old 07-09-2018, 02:34 AM   #3
I would be around 19500 lbs. 13500 lbs for the coach and 6000 for the truck. 22000 lbs is the GCVWR. 14500 is the GVWR.
Old 07-09-2018, 08:49 AM   #4
Duckogram's Avatar
With those numbers you should be fine. The only thing you might need to keep an eye on is your brakes when you go down steep grades.
Happy Motoring
Ducky
ILB ( | )
Old 07-09-2018, 09:06 AM   #5
Total Loss's Avatar
Can you flat tow a Dodge?
Is it 4wd?
I was considering a newer Ford regular cab 4x4 with the 2.7 turbo.
It only weighs 4400 in that configuration thanks to the aluminum body and can be flat towed.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 07-09-2018, 02:22 PM   #6
Send a message via Skype™ to stillontheroad
We have towed our F150 FX4 all across the country with absolutely no problem. We did however have a Holiday Rambler diesel 32 ft. We used a brake buddy for braking. The most important part is to have a proper tow system. We used a Blue Ox.
stillontheroad is offline   Reply With Quote
Old 07-09-2018, 08:03 PM   #7
Yes it is 4x4 and can go into neutral like most Jeeps and be flat towed. I have the rvibrake 2 and a roadmaster nigjthawk tow bar which I just got after using the roadmaster Blackhawk 2 for the last 6 years. I bought it used so I decided to get a new tow bar.
I think I will give it a whirl after I get the blue ox baseplates installed and all the other associated stuff. It would just be an expensive mistake if I doesn’t work out.
Old 07-09-2018, 09:31 PM   #8
Duckogram's Avatar
The only reason it would not work as specified is if you do not have enough power to pull your T-Ruck. In that case, a 5 Star tune can help.
ILB ( | )
Old 07-10-2018, 09:55 AM   #9
Have you weighed your 3010 loaded?
ActionJackson is offline   Reply With Quote
Old 07-10-2018, 05:22 PM   #10
Yes 13500 loaded with about 1/2 tank of water and full fuel.
towing
