Old 10-29-2016, 06:34 PM   #21
RedLdr1's Avatar
Originally Posted by n-e-d View Post
So whats this about donuts?
If you click on either of the photos in my post it will take you to my Flikr folder where the photos are hosted. From there you can see any of the photos in my "Public" folders as well as view the photos in full size instead of the website size limit. That is where the "other" donuts are hiding....
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 Off-line 15 April 2024.
RedLdr1 is offline   Reply With Quote
Old 10-30-2016, 09:58 AM   #22
Hoglou's Avatar
Any thoughts about where to get those black rubber plugs to isolate stem movement?
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 10-30-2016, 10:07 AM   #23
Wait till next year...
n-e-d's Avatar
Valve Stem Extension Stabilizer for Ford F450, F550, F53, E450 Chassis with 16” Steel Wheels VHRG4
Mary and Me
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Iwish Roamer"
n-e-d is offline   Reply With Quote
Old 10-30-2016, 11:42 AM   #24
Chief tinkerer
Gidyupgo's Avatar
ShinyRV.com too
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 10-30-2016, 02:29 PM   #25
Hoglou's Avatar
done did that
Well after great input from fellow C'ers I went with the TST. It came late last night and found it on my front porch around lunch. Installed and ready roll.
Now with a brake controller, XM, second camera, and a TPMS I am about out of dash real estate
You can just see the south bound end of lulu bell on the dash in the pic...
Old 10-30-2016, 02:30 PM   #26
Hoglou's Avatar
tilted
Dang it, its sideways!
Old 10-30-2016, 03:15 PM   #27
RedLdr1's Avatar
They are a bit cheaper, at $11.99 each, at duallyvalve.com. See Here.
Wayne
Old 10-30-2016, 04:10 PM   #28
Hoglou's Avatar
thx
Thanks for the lead..
Old 10-30-2016, 11:44 PM   #29
dukeboone's Avatar
Originally Posted by BendOrLarry View Post
You will like the EEZtire TPMS. I went with the non flow through sensors on my class C. No issues of any kind.
Same here!
2016 Forester MBS 2401S
dukeboone is offline   Reply With Quote
Old 12-17-2016, 06:01 PM   #30
SolSeeker
Still checking out the TST 507, to flow through or not to flow through that is the question. Also checking out the Duallyvalve eight piece chrome valve replacements. Could be just the thing to replace the forest river crap that came OEM. Great stuff for under the tree and in the stocking. DW's going to go crazy this Christmas. A bit spendy but nothing's too good for her.
http://yourtireshopsupply.com/
http://yourtireshopsupply.com/produc...-stems-dl1spfr
dlb
Berny is offline   Reply With Quote
Old 12-17-2016, 06:17 PM   #31
Zooming's Avatar
TPMS
I chose non - flow thru and have found them very adequate.
With the range of Low-High limits set, I found that I rarely need to add any air.
A caveat - I found that the temperature of the tire TREAD is significantly HIGHER than what the sensor reads. Of course the sensor can only measure temperature of the AIR, not the actual tire. My display was showing about 95 degrees, while the tread temp was more like 135!
Zooming is offline   Reply With Quote
