Old 04-08-2016, 12:01 AM   #21
MH Noob
No - you need to order a shunt kit - Am solar has a sweet set up with all connectors and 30 ft of wire for $86.00
Slimjc is offline   Reply With Quote
Old 04-08-2016, 11:17 PM   #22
nodrawers's Avatar
Originally Posted by Garrette View Post
Does the Trimetric come with a shunt?
No, you need to order it separetly. I ordered the 100 not the 500 as I have only 400w solar and like the ability to read amps at .01 instead of .1. Also the SOC % wont read corectly untill battery has reached 100% charge as determined by your inputs.
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 91, 2017 110
nodrawers is offline   Reply With Quote
Old 04-10-2016, 07:49 PM   #23
Garrette's Avatar
Thank you both for your input.
Safe Travels.
Garrette is offline   Reply With Quote
Old 04-13-2016, 08:06 PM   #24
PokerDealer's Avatar
I mounted the shunt on a board with positive and negative battery terminals and a DC fuse box to wire the TM 2030 inside as well as a 12 volt charging station and future needs. I'm running a 4 inch waterproof junction box through the front of the trailer to keep the distance from the batteries to about 3 feet.
2015 Wildwood 181 BHXL. 2005 1500 Ram Hemi 4x4 W/package
PokerDealer is offline   Reply With Quote
converter
