Old 07-26-2013, 08:09 PM   #11
Yes, it has a 12v feed to the back of it. It's made by magnadyne if its the same as mine. Always has power to it. Just punch the button for cable/ ant/ DVD. Like you, I searched for a "boost" button on near the power outlet like my older travel trailer.
4Gcampers is offline   Reply With Quote
Old 07-26-2013, 08:38 PM   #12
wesslvm's Avatar
Same setup on my new 3050S, I had the same question before. I couldn't get TV over air in ME either, but it works locally.
Wes
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 07-29-2013, 05:56 AM   #13
I do see some wires (not coax cable) going into the back of the box that has all of the switches (eg. antenna, dvd, etc..). I'll take a pictue when I get a chance. If I understand what folks are saying it's hard wired to be "always on" when I select the antenna option?
johnlantz is offline   Reply With Quote
Old 07-29-2013, 06:31 AM   #14
Herk7769's Avatar
If your Sunseeker does not have a Winegard roof antenna system, you will need to let us know what type of antenna you do have so we can get the manual for you. That should tell us what you need to be looking for.
HAM CALLSIGN - KC3FFW
Old 07-29-2013, 08:40 PM   #15
Yes it's a winegaurd. I'll try the suggestions when I get back to the RV this weekend.
Old 07-29-2013, 08:46 PM   #16
B and B's Avatar
I took out the stereo in my 8289WS and replaced the 3 out 7.5 db loss per port splitter with a 3 db loss 2 way splitter to feed the bedroom and the living room. I hooked up the tailgating connection in the bay to the output of my living room sat receiver.
Do this increased my digital signal strength by 3 bars on the same station.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-30-2013, 06:34 AM   #17
The last post thoroughly confused me. My wife won't be happy when I have to tell her I'm taking apart things already on the new RV.
All I'm trying to do is watch the same TV stations I could get on my 8-year old RV with my brand new RV... didn't think it would be that hard.
Old 07-30-2013, 06:47 AM   #18
Herk7769's Avatar
You should not have to take anything apart. FINDING the signal selection panel is that hard part as it is floorplan dependent.
Look For:
ID:	36514   Click image for larger version
Name:	Sandpiper Cable connections Bedroom.jpg
ID:	36515   Click image for larger version
Old 07-30-2013, 08:04 AM   #19
B and B's Avatar
Look For:
But if you remove the splitter you get more gain=more channels=more choice in rural areas. In Canada we have areas in populous Southern Ontario you can not get digital tv at all and maybe one noisy analogue channel.
Just a comment that less in the signal path means more channels.
B
Old 07-30-2013, 08:19 AM   #20
Herk7769's Avatar
B
B,
While not helpful to the original poster, I will put my comment to your post. The "signal loss" in a single digital quality splitter is quite small and the range increase would be measured in yards (not enough to make a significant difference in transmission tower reception). IMO
