Old 07-30-2013, 08:47 AM   #21
Commercial Member
Originally Posted by johnlantz View Post
The last post thoroughly confused me. My wife won't be happy when I have to tell her I'm taking apart things already on the new RV.
All I'm trying to do is watch the same TV stations I could get on my 8-year old RV with my brand new RV... didn't think it would be that hard.
Yes, if you have a switch box the booster is "always on".
Make sure the antenna is cranked up and remember it is directional. You can then go into the menu on the TV. The last menu item (if I recall correctly) has a signal meter. You can rotate the antenna to get the best possible signal.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 07-31-2013, 05:15 PM   #22
What we learned with our 2450S recently is that when you plug into a cable TV cord that you have to turn off your antenna booster. If you do not, than the cable comes in like the 70s!! We have the full entertainment center instead of bunks and our switch is in the right side of the TV opening bottom shelf.
markangie24 is offline   Reply With Quote
Old 08-03-2013, 10:41 PM   #23
Commercial Member
With a standard booster that is correct. With the switch box that has different inputs. Some are boosted all the time...some are not boosted ever.
Old 08-09-2013, 09:49 PM   #24
So if I understand everything... the booster is automatically on the box with the switches is set to ANT. If I switch to cable or DVD, then the booster is turned off. There is nothing to do other than selecting ANT on the box.
johnlantz is offline   Reply With Quote
Old 08-10-2013, 09:25 AM   #25
Commercial Member
Correct. In theory, that's how that particular box is supposed to work.
If you decide to run Satellite however, you need to go into the receiver first, then out of the receiver into the switch box. That box still doesn't play well with Sat signal.
Old 11-18-2013, 09:51 PM   #26
Look in the cabinet where your coax goes from the tv to the wall plate, on ours it is a tiny little push button, no light. If you look closely with a flash light you should see it, along with ON/OFF imprinted on the face plate.
mikes2sons is offline   Reply With Quote
